Toymods » Tech & Conversions » 2TG Bearings in a 3TGTE?
inferno
2TG Bearings in a 3TGTE? Thu, 07 November 2002 23:39 Go to next message
I've just bought a 3TGTE, desperately requires a recondition, just wondering what bearings i could use. I've heard rumours 3T rings fit, and 2TG main/end bearings do sort of fit but i have to make sure their oil groves are the same(?).
Also what parts usually need changing for an old 3TG- main end bearings, rings, gaskets, timing chain parts, any parts in the head need replacing?
rob
TE72_Turbo
Re: 2TG Bearings in a 3TGTE? Fri, 08 November 2002 09:59 Go to previous messageGo to next message
3T-C (T18) big end and main bearings can be used, but the big end bearings need the oil hole re-drilled as its about 7mm off from the one that is already there.
Its a good idea to change timing chains,they tend to stretch after many k's, and get noisey.
The short chain is 62 link same as 18R toyota, long chain is 102 link same as 4G52/4 datsun.
A head service wouldnt hurt either, I'm sure the valve guides & seals would be the same as some other toyota twin cam of that era. any head shop can resurface the valves & seats for a better seal too.
Phil
inferno
Re: 2TG Bearings in a 3TGTE? Sat, 09 November 2002 00:21 Go to previous messageGo to next message
hey thanks for the info, i was thinking that the 2TG timing chain would fit for some reason.
TE72_Turbo
Re: 2TG Bearings in a 3TGTE? Sat, 09 November 2002 02:44 Go to previous message
it may well be the same as a 2TG, but its far easier to find a listing for local holdens & datsuns than an imported 2TG Smile
Previous Topic:RT104 Mods
Next Topic:What oil to use on a RA28 with stock motor?
Current Time: Fri Oct 23 16:34:25 UTC 2026
Total time taken to generate the page: 0.0039401054382324 seconds
