| Author | Topic |
Re: FASTEST 7M-GTE IN OZ
Fri, 18 March 2005 07:06
What about fastest 7MGTE in OZ to blow a headgasket?
Fri, 18 March 2005 08:57
| Skip wrote on Fri, 18 March 2005 18:06 | What about fastest 7MGTE in OZ to blow a headgasket?
There would be a lot of contenders
Fri, 18 March 2005 09:28
i'd say that'd be about 30 secs from someone that didn't put the new one back properly.
Fri, 18 March 2005 23:34
| Dori Dori wrote on Fri, 18 March 2005 16:08 | With all this talk of the quickest 1JZ in OZ I figured its time 7M owners started their own list. Now I don't know who has the fastest 7M powered vehicle but i'll start by posting my time.
My PB is a 12.48sec @ 116mph in a 7M MZ20 Soarer
Don't be shy post your times. Its all good.
Dori, what mods have you got?
ill have something to post in a few months.
Sat, 19 March 2005 01:51
Blitz K27, Blitz front mount, GT-R fuel pump i think, big injectors -possibly 800cc, HKS piggy back ecu, Pump fuel, R154.
Car is full weight also.
It should be good for a flat 12 or high 11sec if i can get a better 60ft. The best so far is a 2.0sec
Where are all the 7M owners?
Sat, 19 March 2005 02:25
Nice time dori dori.
Will have to get my mate Daniel to go to the track. He just bought Celicaboy2000's ma70 which has quite a few mods. Seat of the pants says a low 13 to me. But that could be way off.
Sat, 19 March 2005 03:12
| celicaboy_2000 wrote on Sat, 19 March 2005 13:34 | I'd probably say a High 13. Get the Injectors & pump installed, dyno it up plus a couple more pound... I cant wait for Daniel to do all that, I want to see the dyno sheet to see what my old grl can spin.
I have seen a fella's ma70 with a lot less mods that your old car do a 13.8 so anything is possible!
Sat, 19 March 2005 09:51
What kind of mods? I'm keen to see what others are doing.
I know the 7M copped a bad rap for the head gasket but these motors are super tough.
I'd like to have a crack at the JMS time. Might need soem more grunt to run 122mph though.
Nothing a hit of gas couldn't fix.
Sat, 19 March 2005 13:45
I have absolutely no idea what I'd run down the quarter, but I would be curious to see what sort of power you are putting down Dori Dori - that will give me an idea of what I could run.
Sun, 20 March 2005 01:59
300.8kW at the wheels. Not bad for a daily driver. I might come to the next Toymods dyno day for a run.
Sun, 20 March 2005 03:30
That's a lot of kw.
With that sort of power you should be able to improve on your time, shouldn't you?
Wed, 23 March 2005 04:15
If i can better my 60ft times sure, i can go quicker.
I just need more practise. Even if i can record a 1.8sec 60ft I shoudl run a flat 12sec. With some slicks i might even match the JMS time but i will need more power.
There has to be other 7M owners that have run decent times. These motors are making the same as 2JZs in the US.
Wed, 23 March 2005 04:44
I have no idea what I would run down the quarter when I am done with my car, but it isn't high on my priority list.
Main focus will be cct time around Mallala
I love racing through corners and more than 400m at a time
Wed, 23 March 2005 07:32
best was a 14.7
but that was with a fuxxed auto gearbox, with the new 5sp manual im hoping for a low 14. be taking it to the plex next week.
Thu, 24 March 2005 12:56
hah.. fastest hoon on teknoscape!
not sure what my times are, but someone sell me a R154 dammit so i can be worthy of a post..
Fri, 25 March 2005 00:50
roflcopter
Fri, 25 March 2005 23:33
Dori Dori: the mods are
7MGTE motor been rebuilt 5000km ago:
- Balanced flywheel, crank & harmonic balancer
- Big end bearings
- ARP conrod bolts
- Pistons balanced & HPC coated
- Rings
- 2mm HKS MHG bead type
- ARP Head studs
- New water pump
- New spark plugs
- Highflowed CT26-to4 (just been rebuilt, new seals balance etc)
- 3" Mandrell bent exhaust
- Greddy front mount intercooler
- HKS SSQV BOV + Purple fin
- K&N pod filter
- Wolf Ver4 engine management system + RB20 optical sensor
- Custom thermo fans (AU falcon)
- Ceramic button clutch with modified pressure plate (more clamping pressure)
- Turbosmart single stage boost controller
- TRD radiator cap
- Short shifter
- New radiator
- New battery
- New high pressure powersteering hose
- New Accordian hose
and has a walbro and 660's to go in.
Sat, 26 March 2005 00:59
Sat, 26 March 2005 02:48
| bathurst-91 wrote on Sat, 26 March 2005 11:59 |
what did it run?
Sat, 26 March 2005 03:08
and why oh why only 426hp? I'm assuming that's at the wheels, but even so it's not super impressive considering the size of the turbo hanging off the side of it
Sat, 26 March 2005 04:22
dori dori your car sounds very similar to the car ben ellis used to own.
Sat, 26 March 2005 05:26
Thought id post this one BLCJET in the december 2003 issue of fast fours is a 1988 toyota supra ma71 putting out 565 killowatts at the wheels a 727kW or so at the crank doin a 12.48 at 133mph. to much stuff to post thats some 7mgte powah.
chase.
Mon, 28 March 2005 09:08
Yes its the same car
Tue, 29 March 2005 11:56
are you the dude from zoom then? i was just reading the editorial bit at the start there and then i read this
Tue, 29 March 2005 13:40
Posting on behalf of a mate who doesn't browse these forums.
12.3 @ 110mph with a best mph of 113mph. High flowed CT-26, ex Group A TRD motor, MV Auto built auto. I believe it had around 250rwkw when it ran those times (over 3 years ago, it collects dust now )
Mods now include custom intake plenum, GT40, 1200cc jets, M800, not quite finished but will be shortly.
His page can be found here > http://www.turbosupras.com/pages/members/ma70/ntse mitsidis.htm
Wed, 30 March 2005 02:33
previous owner did 14.3 before i bought it and it blew the headgasket
thats a stock 7mgte in an ma61 with W58 and full 3" exhaust, running on 5psi
Wed, 30 March 2005 03:19
| sprinter_86 wrote on Sat, 26 March 2005 16:26 | Thought id post this one BLCJET in the december 2003 issue of fast fours is a 1988 toyota supra ma71 putting out 565 killowatts at the wheels a 727kW or so at the crank doin a 12.48 at 133mph. to much stuff to post thats some 7mgte powah.
chase.
Surely with that much power it would of done a quicker quarter, unless it had massive issues with power down.
Wed, 30 March 2005 04:12
Its just a dyno queen, no power till about 6000rpm
Wed, 30 March 2005 04:29
chase.
Yeah, and reading the article i see, on his first outing he blew a headgasket .
Wed, 30 March 2005 05:01
its one thing to make power, its another thing to convert that into good 1/4 mile times. it aint a simple as plant the foot and it all happens
blcjet is a dyno comp winner designed car. its hasnt been designed to do anything but win dyno comps and blow head gaskets.
Sun, 03 April 2005 06:17
dori dori how much boost are you running to get 300kw?
Spence
Sun, 03 April 2005 06:27
| Spence wrote on Sun, 03 April 2005 16:17 | dori dori how much boost are you running to get 300kw?
Spence
Looks like someone bought an importbitz car!
I did the same a few weeks ago, it will work out much cheaper than doing a conversion to the 61, except i went the z20 route.
Sun, 03 April 2005 12:29
oh yeah couldn't resist but i really like my ma61 and i like the fact that its bout 400kg lighter than the ma70
Mon, 04 April 2005 01:53
Spence: 21psi for 300kW.
Wed, 27 April 2005 00:17
| Corona RT142 wrote on Wed, 30 March 2005 13:19 |
chase.
Its also in the gold edition of fast fours and he said he blew both a gearbox and a diff trying to do the quarter mile. so they fixed them and then the owner didn't want to break anything else so he let the guy who helped him tune it drive and and as it only has a single spinner (i have no idea why....) just drove it off the line and did like a 2.6 or 2.8 second 60 foot time.
but yeah that engine bay is insane. I love it.
Sat, 30 April 2005 16:54
OK I havent hit the quarter yet but so far have cut 302.8kw at the wheels on my 7M-GTE at 18psi. I have an MA-70, whats the weight difference between a Soarer and a Supra I forget and I dont have my brochures with me at the moment. Manual seem to be alot harder to get a good time out of in these cars than auto. I also need to get max power out of my motor the last dyno session was cut short should be able to run 25psi.
Either way I know the time will not be indicative of the engine power, however I am considering converting it to auto for a while to get some times out of it, especially now that I found out that apparently the OS cross gears I purchased dont adress the thrust washer issue in the R-154 which is the main weakness with them.
Any more 7M-GTEs to come out of the woodwork?
Sat, 30 April 2005 21:52
Sorry ive ive missed something hear , What mods we looking at for the 300rwkw ??
| HKS_TRD wrote on Sun, 01 May 2005 02:54 | OK I havent hit the quarter yet but so far have cut 302.8kw at the wheels on my 7M-GTE at 18psi. I have an MA-70, whats the weight difference between a Soarer and a Supra I forget and I dont have my brochures with me at the moment. Manual seem to be alot harder to get a good time out of in these cars than auto. I also need to get max power out of my motor the last dyno session was cut short should be able to run 25psi.
Sat, 30 April 2005 23:13
| HKS_TRD wrote on Sun, 01 May 2005 02:54 | the thrust washer issue in the R-154
dude get a washer made max $50, but i do prefer auto
Tue, 03 May 2005 10:08
| 1200det wrote on Sun, 01 May 2005 07:22 | Sorry ive ive missed something hear , What mods we looking at for the 300rwkw ??
Not sure how much detail you want but the motor has forged pistons big cams etc and I run a GT 3540 Turbo. Still a few bits and pieces to finish up on it and then push more boost through it.
