Toymods » Tech & Conversions » Help I got clutch problems
chris185
February 2005
icon9.gif  Help I got clutch problems Fri, 18 March 2005 10:46 Go to next message
Hello all,
I've been having problems with, well the gear won't engaged for the second time now. What happened was after driving for about 15 mins then I came to a stop light when it was time to go it won't go into first gear or any gear for that matter. So I killed the engine then engaged it after that it work fine for about a couple of weeks. Then again one day after about driving for half an hour to pick up my son from school, started the engine and it happened again it won't engage! Lately I've been pushing the clutch pedal all the way to the floor, check the fluid reservoir it's still full, it was suggested that I check the slave cylinder ( for leaks ) but I don't know where that is, even if I find it it's not it wouldn't be leaking because the reservoir is still full. Any help will be appreciated.
Please help
Chris ( ST185 )
Nolan
Campbelltown, NSW
Re: Help I got clutch problems Fri, 18 March 2005 10:53 Go to previous messageGo to next message
hey buddy,
same thing was happening in my mates AW11, by the sounds of it, it could actully be your clutch,
we took his clutch out and the clutch plate had shattered Razz..
take it to a mechanic
CHEERS
NOLAN
chris185
February 2005
Re: Help I got clutch problems Fri, 18 March 2005 11:45 Go to previous messageGo to next message
Thanks Nolan,
I suspected it was the problem, I just wanted a more expert opinion you see when I take off pretty hard there's this horrible smell. Again thanks
If there's anyone out there that can help whether the type of clutch plate I should get or other opinion please don't hesitate to answer my question.
Thanks in advance
Chris
styler
Re: Help I got clutch problems Sat, 19 March 2005 22:56 Go to previous messageGo to next message
sometimes the master cylinder seals are stuffed and the
annoying thing is they dont leak to show it. get someone
to push on the master and look at the clutch fork for
movement.
Re: Help I got clutch problems Sun, 20 March 2005 12:42 Go to previous messageGo to next message
Nolan wrote on Fri, 18 March 2005 21:53
hey buddy,
CHEERS
NOLAN
no shit!..
i had this problem recently also... 1/4 of the friction plate decided to wedge itself into the pressure plate Sad
get someone else to push the pedal and visually check the fork is being pushed.. also bleed it again with totally new fluid, just in case.
other than that, drop the box and check the clutch
g/luck
chris185
February 2005
Re: Help I got clutch problems Wed, 23 March 2005 06:03 Go to previous message
Thanks Styler and Old Corollas.
At the moment I'm taking it easy with the driving and hopefully I'll get some time to have it looked at. I will certainly do the things you suggested and maybe I can fix it myself.
Again Thanks
Previous Topic:Can someone identify my diff(s)?
Next Topic:4AGE vs 2TG
Current Time: Tue Oct 20 23:01:56 UTC 2026
Total time taken to generate the page: 0.01242208480835 seconds
