Toymods » Tech & Conversions » Choice turbo for a custom bolt on turbo setup?
kemicalx
Geelong.Vic.Au
Choice turbo for a custom bolt on turbo setup? Fri, 18 March 2005 11:01 Go to next message
Now it's not a Toyota I plan on building this for, but i'm thinking a CT turbo might be the way to go (always plenty for sale pretty cheap)
The motor is a Mazda BP01 (1.8lt 16v sohc) I'm not sure which of the CT's would better suit my application. the CT12 seems too small, perhaps the the CT20 or 26? what would you suggest? The car will likely run a max boost of 8-10psi intercooled.
Ashlin.
rb20det
Re: Choice turbo for a custom bolt on turbo setup? Fri, 18 March 2005 12:45 Go to previous messageGo to next message
id got something with a gt25/28 or t3 flange as these are the popular turbos atm. gt25s of ca18dets/sr20s sell for around $200 in good condition and will run 10psi all day. garret makes f.ukin good turbos
kemicalx
Geelong.Vic.Au
Re: Choice turbo for a custom bolt on turbo setup? Fri, 18 March 2005 13:02 Go to previous messageGo to next message
internally or externally gated?
I want to use this manifold (slightly modified) http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?Vi ewItem&category=33742&item=7961736069& rd=1
Presuming I got a internally wastegated turbo fitted, could I just use a little plate over the external wastegate baffle to cover it up?
berad
Re: Choice turbo for a custom bolt on turbo setup? Sat, 19 March 2005 06:32 Go to previous messageGo to next message
most places that sell those manifolds over ebay have other manifolds that suit internally gates turbos send them a email and ask if they make ones for internaly gated turbos
Bert
Re: Choice turbo for a custom bolt on turbo setup? Sat, 19 March 2005 06:55 Go to previous messageGo to next message
you could use a BP turbo motor out of a familia. advantage is its twin cam, low comp, efi and similar to your engine already. might save a few dramas jus to sway engine....just an idea to throw in the mix
kemicalx
Geelong.Vic.Au
Re: Choice turbo for a custom bolt on turbo setup? Sat, 19 March 2005 07:19 Go to previous messageGo to next message
hehehe i thought i might get away from people suggesting the BPT on toymods, no such luck Razz
thanks for the suggestion, you are 100% correct the BPT is really a simple option for boosting my car. However i'm going to stick with the sohc motor, using standard compression. A couple of people in the states have done it, but no one in australia as far as I can tell.
I want to do something diferent. And the satisfaction of getting my own turbo setup running would be great. Besides i'm not after huge power. Arounds 100-120fwkw.
cheers.
oh btw, my motor is EFI too.
berad
Re: Choice turbo for a custom bolt on turbo setup? Sat, 19 March 2005 07:30 Go to previous messageGo to next message
wat compression does ur engine have?
kemicalx
Geelong.Vic.Au
Re: Choice turbo for a custom bolt on turbo setup? Sat, 19 March 2005 07:52 Go to previous message
12.2 which is why I won't be running over 10psi (more likely 7-8)
edit - BTW the dohc version of my motor is 12.8 and the BPT is 11.5
[Updated on: Sat, 19 March 2005 07:55]
Previous Topic:7AGE stock set-up dyno... anyone here???
Next Topic:HILUX DISC CONVERSION
Current Time: Wed Oct 21 02:54:14 UTC 2026
Total time taken to generate the page: 0.0056650638580322 seconds
