Toymods » Tech & Conversions » HILUX DISC CONVERSION
81LOWLUX
BRAY PARK BRISBANE
March 2005
icon5.gif  HILUX DISC CONVERSION Fri, 18 March 2005 22:29 Go to next message
Has anyone used 91 4x4 calipers on a rn41 hilux?
I currently have 4wheel drums and want to change the front brakes to disc the problem being is that i want realy good stoping power because i am either using a turbo motor or a bombed holden 304 brock motor. the 91 4x4 calipers are 4 piston, will they work with 84 4x2 discs because they bolt straight on. please help.[COLOR=limegreen]
boudan
Re: HILUX DISC CONVERSION Fri, 18 March 2005 23:40 Go to previous messageGo to next message
Are you;
A. Swaping the complete setup ie- drum to drum for disc to disc
B. Trying to figure if the axle length, dia, splines are the same
C. Attempting to remove drums, bolt in discs
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: HILUX DISC CONVERSION Sat, 19 March 2005 00:48 Go to previous messageGo to next message
my car is a 4x2 petrol rn41 hilux. I am removing the drums and replacing with discs, they need to be the same stud pattern, height and offset. The 84 4x2 discs bolt sraight on (stubaxles, rotors and calipers) but i would like 4 piston calipers for better stoping power. It needs to be legal and cheap, 84 conversion is $170 from the wreakers, compleate. If the 4x4 calipers dont fit on the 4x2 stub axles is there another redaly aval 4 piston caliper that works?
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: HILUX DISC CONVERSION Sat, 19 March 2005 02:13 Go to previous messageGo to next message
nobody seams to know an answer someone help please............ Sad Dont want to end up a tangle mess!
YelloRolla
On your mum!
Re: HILUX DISC CONVERSION Sat, 19 March 2005 07:17 Go to previous messageGo to next message
The RN 41 was available with discs (I had one), get the disc set up and bolt it all on there, they work well. edit/ you may need to swap over the whole stub axle assy.
The brake set up of the 4WD will not fit AFAIK(you would need to measure up and check it out).
You may be able to use the discs off the BA Falcon (same bolt pattern) and PBR calipers, but again you will need to check it out as we are not all of the same ability.
[Updated on: Sat, 19 March 2005 07:27]
YelloRolla
On your mum!
Re: HILUX DISC CONVERSION Sat, 19 March 2005 07:30 Go to previous message
Another thought -
The mounting holes for the 4 spot caliper are 90mm C/C and the RN41 disc caliper is about 110mm from memory (you could make a new caliper mounting bracket).
Previous Topic:Choice turbo for a custom bolt on turbo setup?
Next Topic:Where do i buy forged pistons & VRS kit for 3tgteu
Current Time: Fri Oct 23 04:04:02 UTC 2026
Total time taken to generate the page: 0.0042679309844971 seconds
