Toymods » Tech & Conversions » supercharged 3k?
kdogg
leumeah NSW
supercharged 3k? Sat, 19 March 2005 03:49 Go to next message
a mate of mine says it is possible to supercharge a 3k just for something different. Is it possible and if so where do you get the parts?
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: supercharged 3k? Sat, 19 March 2005 04:16 Go to previous messageGo to next message
its possible.
depends which parts you want.
supercharger - look for almost any jap importer/wrecker
the rest is too specific for me to be bothered with.
Sam_Q
S.E suberbs, Vic
Re: supercharged 3k? Sat, 19 March 2005 10:53 Go to previous messageGo to next message
I have seen it done before, don't know why anyone would bother though
Re: supercharged 3k? Sun, 20 March 2005 12:44 Go to previous messageGo to next message
kdogg wrote on Sat, 19 March 2005 14:49
you can supercharge just about any 4 stroke motor.
you get an SC12 or SC14 and you make the parts. simple as that.
EldarO
Perth, WA
Re: supercharged 3k? Sun, 20 March 2005 14:40 Go to previous messageGo to next message
SC12 is ghey wit teh aids from what ive heard, sc14 can pump out 15psi with enough driving power!
id just slot in a 4AGZE but then again, each to their own!
Re: supercharged 3k? Sun, 20 March 2005 22:46 Go to previous messageGo to next message
EldarO wrote on Mon, 21 March 2005 01:40
how do you figure that? SC12 with 15psi on a 1.6L might be a problem, but on an 1100 or 1300 motor? isn't it a combination of temp from compression AND temp from high lbe speed that causes the lobes' coating to fail?
boofis
MELBOURNE
Re: supercharged 3k? Mon, 21 March 2005 20:43 Go to previous messageGo to next message
[/quote]
how do you figure that? SC12 with 15psi on a 1.6L might be a problem, but on an 1100 or 1300 motor? isn't it a combination of temp from compression AND temp from high lbe speed that causes the lobes' coating to fail?[/quote]
One thing to say, you know too much, good work. What would a turbo go like on a 3k? lol!
Troy
Re: supercharged 3k? Mon, 21 March 2005 22:07 Go to previous messageGo to next message
my only reservation with forced induction on a K series motor is the pistons. the original repco/toyota ones are fragile at best, but i have yet to see how the ACL ones stand up to pressure.
i would prefer ones with shorter skirts..
ke35 - 4AGZE
Re: supercharged 3k? Tue, 22 March 2005 03:05 Go to previous messageGo to next message
i have been pondering over this recently as il have a spare sc12 setup lying around after i turbo the gze..
i figure get a 3k block put a 4k head on to lower compression, enclose the carby in a box as to keep equal pressure outside the carby not just plumb it straight in,resulting in a blown up carby..
yeh thats my basic idea..but im a newbie to the k series engines so let me know if im wrong.
is the theory correct or am i kidding myself..
btw this is in a ke70.. Razz
[Updated on: Tue, 22 March 2005 03:07]
Re: supercharged 3k? Tue, 22 March 2005 11:35 Go to previous messageGo to next message
theory is sound, hardest part will be the carby.. fuck it off and put on EFI Wink
ke35 - 4AGZE
Re: supercharged 3k? Tue, 22 March 2005 19:49 Go to previous messageGo to next message
lol..
no no, the ke70 is a minimum expence project
smitty1
Re: supercharged 3k? Wed, 23 March 2005 01:27 Go to previous messageGo to next message
If you wanted to stay carby, you would have to be better off going suck through rather than blow through.
ke35 - 4AGZE
Re: supercharged 3k? Wed, 23 March 2005 02:42 Go to previous messageGo to next message
ok,
how would you set this up??
needs to b an easy otherwise i wont bother doing it..
to do the blow through, i was just going to make a box that bolts onto the where the carby sits put the carby inside this box and plumb the sc in before this, probably with a small intercooler as well..
have u got any pics of a suck through system??
styler
Re: supercharged 3k? Wed, 23 March 2005 08:48 Go to previous messageGo to next message
if you want an intercooler though it will have to be blow thru
Re: supercharged 3k? Wed, 23 March 2005 12:29 Go to previous messageGo to next message
ke35 - 4AGZE wrote on Wed, 23 March 2005 06:49
lol..
lets see... $200 for ECU, $300 for EFI manifolds....$100 for fuel pump...
sounds cheap to me Wink
ke35 - 4AGZE
Re: supercharged 3k? Wed, 23 March 2005 19:57 Go to previous messageGo to next message
yep exactly
sounds cheap to me
hmmm sounds interesting....
will think about it more when im finished on the ke35 Cool
Sam_Q
S.E suberbs, Vic
Re: supercharged 3k? Thu, 24 March 2005 10:26 Go to previous messageGo to next message
$200 for an ECU?? which one? and what about the rest?
Jezza
Re: supercharged 3k? Thu, 24 March 2005 11:18 Go to previous messageGo to next message
any old fuel only ECU wont set u back much
my Haltech F9 cost me $350, thats ECU loom and sensors
and its not even that old!
Sam_Q
S.E suberbs, Vic
Re: supercharged 3k? Thu, 24 March 2005 11:28 Go to previous message
if your getting an upgraded ecu then it would be stupid to not upgrade the igniton, the original points setup is barely strong enough ignite the original mixture let alone with boost to blow it out. Also you didnt consider the cost of all the accessories and the tuning.
Previous Topic:where to get Cro-Mo pipe + Carbon and use of carbon
Next Topic:ke70 - 2nd part drive shaft for T series Diff?
Current Time: Wed Oct 28 07:17:42 UTC 2026
Total time taken to generate the page: 0.01029109954834 seconds
