Toymods » Tech & Conversions » Boost Control install
Nimrod
Melbourne Victoria
Boost Control install Sat, 19 March 2005 12:24 Go to next message
Heys, i recently installed my GFB Boost controller just a simple bleed valve type and it was okay for a bit but then it started to spike and hit boost cuts... not cool, i insatlled it fairly close to the turbo could this be because the heat from the turbo gets into the seals and cause it to leak then spike? thanks
[Updated on: Sat, 19 March 2005 12:25]
Yian
Lwr Templestowe, Melbourne
Re: Boost Control install Sat, 19 March 2005 21:05 Go to previous messageGo to next message
Has this happened recently? If so, its probably coz the weather has gotten cooler the last few days. And cool air being denser, you will hit boost cut a lot easier than when its hot. So, turn it down. And problem is solved.
Nimrod
Melbourne Victoria
Re: Boost Control install Sat, 19 March 2005 22:57 Go to previous message
thanks ill give it a go, yeah i set it on a hot day then it was cold a week later and it was boost cutting heaps.
Previous Topic:keeping it NA
Next Topic:13BT in KE10
Current Time: Sat Oct 17 19:46:09 UTC 2026
Total time taken to generate the page: 0.0051219463348389 seconds
