Toymods » Tech & Conversions » engine timing with 98RON
gorgan
engine timing with 98RON Sun, 20 March 2005 05:35 Go to next message
I have started using 98RON fuel recently and i have realised that its much better performance then ordinary 91/92RON fuel. But whenever i step on the accelerator there is a heap of unburnt fuel and a bit of oil that jumps out of my exhaust. I dont know what it could be except for engine timing. Maybe the exhaust valve opens too early and the combustion stage doesnt have enough time to burn the fuel properly, so the unburnt fuel just runs out of the exhaust.
Has anyone changed their timing after running 98RON fuel? Does it help with this situation?
thanks Smile
Hunty
Re: engine timing with 98RON Sun, 20 March 2005 06:31 Go to previous messageGo to next message
higher octane allows more timing advance before detenotation (pinging)
what i used to was run a couple of tanks of premium to make sure i had got rid of all teh 91 octane fuel then i would adjust my timing untill i could hear it start to ping then back it off about 2 or 3 degrees. for example i was running about 13degrees of advance on the 4age.
HTH
gorgan
Re: engine timing with 98RON Sun, 20 March 2005 09:24 Go to previous messageGo to next message
cheer's, ill have a play around with the timing soon and see if i can get rid of the raw fuel spitting problem.
thanks mate Smile
Kyosho
Wollongong
Re: engine timing with 98RON Sun, 20 March 2005 10:07 Go to previous messageGo to next message
A higher octane fuel, takes a higher temperature, and a longer duration to ignite properly...
When you first hit the gas, if the car is EFI, you will have an "acceleration" injection (Don't worry about that)
But when this happens, basically for a split second some more then usual fuel is injected to counter act the extra air, but with your timing, the fuel is not having enough time to burn that extra amount completely out...
Corona RT142
Campbelltown
Re: engine timing with 98RON Sun, 20 March 2005 10:47 Go to previous messageGo to next message
wouldn't a higher octane fuel actually ignite at a lower temperature think about it, there is more octane molecules thus there is more active ingredients which would mean it would ombust earlier.
gorgan
Re: engine timing with 98RON Sun, 20 March 2005 11:16 Go to previous messageGo to next message
Kyosho wrote on Sun, 20 March 2005 21:07
yeah thats what i thought would be the problem too, the fuel doesnt have enough time to burn and then exhaust valve opens too early and lets some of the raw unburnt fuel out.
but maybe its something else :S
brett_celicacoupe
townsville NQLD
Re: engine timing with 98RON Sun, 20 March 2005 11:29 Go to previous messageGo to next message
Confused
not sure that ignites at lower temp.
if you say that there is more octane molecules in the higher octane fuel.....then it should theoretically take longer and need more energy for the octane to react with the air.
hypothetical situation;
STANDARD fuel: 50 octane molecules in 1 mL petrol
HIGH OCTANE fuel: 80 oc. molecules in 1 mL petrol
say it takes .1 second to combust 1 octane and air molecule......then it takes 5 seconds to burn 1 mL of standard petrol.
so it will then take 8 seconds to burn 1 mL of high octane petrol.
so, advancing the timing will allow the reaction to begin a little earlier and have enough time to react the octane with the O2 completely
it probly wont be a linear type of reaction (ie. 1 mol. burns, then another, then another).....it will be more like 1 molecule of O2 and octane combusts, and passes of required activation energy to other molecules. it continues to get faster and faster
so.....more octane molecules will take more energy to combust/react but NOTE that: generally, molecules have more energy at higher tempertures
so what RT142 is saying....means that the reaction will just most likely go slower at lower temps. fuel WILL ignite at nearly any temperature but the rate of reaction will vary.
did that make sense??? Confused i **think** that may be right
my theory anyway
brett
[Updated on: Sun, 20 March 2005 11:37]
Re: engine timing with 98RON Sun, 20 March 2005 12:31 Go to previous messageGo to next message
i think it's more to do with the higher octane fuels burning slower.
best power/torque occurs when the peak cylinder pressures are X degrees ATDC. the only reason you change advance is to match the fuels burn speed to get peak pressure at that angle.
the "octane" used for the rating (i believe) is 2,3,4 trimethyl Pentane. not octane per se. octane rating is simply a measure of detonation resistance.
the 'higher octane' fuel we get simply means it has a higher proportion of MORE BRANCHED fuel molecules regardless of wether the molecule has 8 carbons or not... since the more the branching, the more evenly it burns and the less likely it is to break molecules prematurely (ie detonation)
so basically, you need to advance timing because the higher branched molecules in high octane fuel burn slower and it takes more time to generate peak cylinder pressures..
fwiw, nitromethane requires around 60 deg advance....
anyway, it's late but it's something like that..
oh, and as for avgas, it has a "high octane rating", so it is designed to be highly detonation resistance (hard to shut down a plane motor thats pinging while flying..) BUT this also means it has a slow burn rate, which in turn is why ppl run much more adance with avgas... BUT, thi salso means that a high rpm motor may not get as much benefit as a low rpm motor, sinc eyou may not have enough time for an effective burn at high rpm..
aaaanyway..
Kyosho
Wollongong
Re: engine timing with 98RON Sun, 20 March 2005 22:19 Go to previous messageGo to next message
Our "higher octane" fuels are a longer chain, yet they are more "compact" and actually harder to get to ignite...
When you try to ignite them, they take a higher temperature to actually get them to properly ignite.
Once they have ignited, it takes longer to get it to all completely burn because of the molecule design.
For this reason, more timing is needed, and also, detonation and pinging is avoided more.
Re: engine timing with 98RON Sun, 20 March 2005 22:44 Go to previous messageGo to next message
Kyosho wrote on Mon, 21 March 2005 09:19
are you sure it's a much higher "ignition" temperature or "auto-ignition" temperature?
gorgan
Re: engine timing with 98RON Thu, 24 March 2005 02:49 Go to previous message
hey all, i timed my engine to about 13 degrees today, i hope thats right Razz shes a bit better fuel economy too Smile thanks all
Previous Topic:Are the R154 & W58 bellhousing flanges even similar??? (3SGTE RWD)
Next Topic:1J AIR CONDITIONER
Current Time: Mon Nov 23 02:04:53 UTC 2026
Total time taken to generate the page: 0.012109041213989 seconds
