Toymods » Tech & Conversions » R&R Heater in MX83 Cressida
YelloRolla
On your mum!
R&R Heater in MX83 Cressida Sun, 20 March 2005 09:15 Go to next message
The heater in the Cressida is leaking Sad and there is a little bit of pink coolant staining on the grey carpet (very 80's).
I have bypassed the heater for now, and I have had a little look at what the job may require; looks like a rather large job.
Has anyone removed/replaced the heater in an MX83?
If so; what is involved (pulling the dash apart or is it necessary)?
Is there any tips involving removing/replacing the heater that I can employ?
Do I need to replace the whole plastic box and dice? Or am I able to remove the core from the box, without destroying the box?
Thanks in advance
[Updated on: Sun, 20 March 2005 09:18]
Re: R&R Heater in MX83 Cressida Sun, 20 March 2005 09:43 Go to previous messageGo to next message
If it's anything like an MA71 (which it will be), you're up for a bastard of a job. The whole dash has to come out before you can even see the heater core, and getting everything back together properly is a nightmare.
Good luck!
YelloRolla
On your mum!
icon14.gif  Re: R&R Heater in MX83 Cressida Sun, 20 March 2005 09:45 Go to previous messageGo to next message
Norbie wrote on Sun, 20 March 2005 20:43
Good luck!
TOPS Confused
Allan
Re: R&R Heater in MX83 Cressida Sun, 20 March 2005 10:53 Go to previous messageGo to next message
http://www1.jaycar.com.au/productView.asp?ID=YS280 5&CATID=&keywords=ceramic+heater&SPECI AL=&form=KEYWORD&ProdCodeOnly=&Keyword 1=&Keyword2=&pageNumber=&priceMin=& ;amp ;priceMax=&SUBCATID=
probably can get the core out easy once the pipes are cut off it then stuff one or two of those suckers in the hole, thats the plan for the ma70 and ma45, less hoses = more reliability
[Updated on: Sun, 20 March 2005 10:54]
manmx83
Re: R&R Heater in MX83 Cressida Sun, 20 March 2005 13:11 Go to previous messageGo to next message
You may find specific info to remove the heater on toyotacressida.com
Best of luck.Pete.
YelloRolla
On your mum!
Re: R&R Heater in MX83 Cressida Mon, 21 March 2005 00:28 Go to previous messageGo to next message
nice work - I will check it out. Let me know how your installation goes.
Re: R&R Heater in MX83 Cressida Mon, 21 March 2005 01:28 Go to previous messageGo to next message
After like the 10th leaky heater in the RA28 I brought one of those jaycar cores to try fitting.
It's still 'work in progress' but seems easy enough.. My concern though is it doesn't give out a lot of heat and it draws 25amps or so. So running 2 wouldn't be possible I don't think.
YelloRolla
On your mum!
Re: R&R Heater in MX83 Cressida Mon, 21 March 2005 01:32 Go to previous messageGo to next message
With the RA28 I am wondering why you haven't had a new core soldered to your end tanks at teh local radiator shop (this makes the assumption that you have been using wrecking yard models because of so many leaking cores).
Re: R&R Heater in MX83 Cressida Mon, 21 March 2005 01:50 Go to previous message
That assumption was partly correct Smile - until the last replacement that was a brand new job from the radiator shop. It lasted a bit longer than the others, around 2 years I think this time.
Heater cores don't like me Sad
Edit - should mention that 10 was an exaggeration. Been through enough though to know how to get the dash apart & back together in record time.
[Updated on: Mon, 21 March 2005 01:51]
Previous Topic:1jz - oil pressure sensors
Next Topic:ae101 4agze conversion --> ae92 SX baby. . .Pls Advise
Current Time: Sat Nov 21 03:39:00 UTC 2026
Total time taken to generate the page: 0.0043699741363525 seconds
