Toymods » Tech & Conversions » 1jz power outputs
tyottsoarer
Gold Coast
1jz power outputs Sun, 20 March 2005 12:05 Go to next message
Just after some peoples guesses on power outputs with these common 1jz mods. Assume the car is manual (r154). I'm guessing the car itself is irrelevant.
STAGE 1
1.0 bar of stable boost (any digital controller)
Front mount intercooler
standard "y" pipe
3" exhaust and 3" high flow cat
440cc 2jz injectors
SAFC II, with a suitable tune for all pre-mentioned mods
Estimation of 230rwkw
STAGE 2
Higher capacity fuel pump
High flowed, steel wheeled ct12a turbos
3" dump pipe
Boost increased to the maximum efficiency of the modified ct12a
Estimated power 250rwkw?
STAGE 3
Adjustable cam gears
256 degree cam shafts on inlet and exhaust
Estimated power ???rwkw
Basically after peoples guesses on the power output on each stage, also suggestions on parts not covered that may have been missed.
manmx83
Re: 1jz power outputs Sun, 20 March 2005 12:52 Go to previous messageGo to next message
stage one is about right provided you swap in dump pipes and swap out 440cc injectors.
You can do that power level on stock injectors [or 225rwkw at 15psi] but need a good flow exhaust.
Your turbos will thank you with a long and happy life due to reduced back pressure and associated heat.
I am not guessing or using second hand info,I am quoting my setup.I believe you should have a bigger fuel pump right away also,Walbro is good.[for soarer dump pipes Lew of Marlew Engineering I think]
Stage 2,wow if you only get 20 or 30 rwkw for 2000 bucks worth of steel wheel hi flo ct12a's you wouldnt do it,surely? I would also like to know what these are capable of and how they would compare with nissan turbos like little GTR t28's which can do a combined 500hp at the flywheel [two] or t28's off an rb20.I dontb pretend to know a lot about these,quoting stuff s/hand here.[see "gtr t28" search for sale engines etc]
Stage 3 you would be looking for some control over ignition timing as well.
Should get plenty of replies,Cheers.Pete.
[Updated on: Mon, 21 March 2005 18:18]
tyottsoarer
Gold Coast
Re: 1jz power outputs Sun, 20 March 2005 12:58 Go to previous message
250rwkw was a conservative guess, I have no idea what they are capable of flowing to or what their maximum boost efficiency is but thanks a lot for your power quote manmx83
Previous Topic:1jz MX83 Questions
Next Topic:Lengthening control arms
Current Time: Sat Nov 21 03:04:40 UTC 2026
Total time taken to generate the page: 0.0067710876464844 seconds
