Toymods » Tech & Conversions » where did 2nd gear go?
time2play
On Probation
February 2005
where did 2nd gear go? Sun, 20 March 2005 14:49 Go to next message
hey peoples,
i dont know much about cars and would like a little help before i head down to a mechanic.
problem: i was driving home tonight changing gears out of 1st i crunched into 2nd, wen it finally got in (little struggle) it was gone, like no 2nd gear at all. 2nd,4th and reverse are gone but however reverse works only when it wants to. its easy to put in gears but when letting go of the clutch, nothing happens.
any advice or feedback would be greatly appreciated Smile
oh and its a 91 rolla
[Updated on: Sun, 20 March 2005 14:54]
mick
toowoomba qld
Re: where did 2nd gear go? Sun, 20 March 2005 14:55 Go to previous messageGo to next message
I think maybe you clutch is on it's way out mate. Usally If you can get reverse without any sign of clash it's a sign the clutch is operating correctly,. But by the sounds of it the clutch may be gone.
Hope what ever it is it doesn't cost you too much Smile
time2play
On Probation
February 2005
Re: where did 2nd gear go? Sun, 20 March 2005 14:58 Go to previous messageGo to next message
same, i just got the car to Sad , clutch dusnt seem to be slipping in 1st and never slipped before.
cheers,
ahmed Smile
[Updated on: Sun, 20 March 2005 14:59]
GZE-STYLE
Camden
Re: where did 2nd gear go? Sun, 20 March 2005 23:29 Go to previous messageGo to next message
check your shifter cables.
time2play
On Probation
February 2005
Re: where did 2nd gear go? Mon, 21 March 2005 04:22 Go to previous messageGo to next message
shifter cables look normal,
i heard it could be my gearbox mounts, anyone correct me on this? how could i check if its my mounts??
Re: where did 2nd gear go? Mon, 21 March 2005 04:50 Go to previous messageGo to next message
let me see.
you engage second gear (or 4th) let out clutch, and then you have no forward motion...
must be gearbox mounts Wink
and you wondered what that nasty sound was? the engine and gearbox rotating in the engine bay perhaps?? Laughing
sound slike broken cables (but you checked that), broken selector shaft, broken shift fork etc etc..
if the other gears work fine, the clutch is likely ok.
is odd that 2nd and 4th are gone, and not 1/2, or 3/4... maybe it's not shift forks...
it does sound like the shifter mechanism is the culprit.
time to get out the manual for your car and have a look Smile
time2play
On Probation
February 2005
Re: where did 2nd gear go? Mon, 21 March 2005 05:00 Go to previous messageGo to next message
hey, thanks for the info!!!
i took the car for a quick hot lap around the block, to my suprise all gears were there again, but after a while disappered. i stopped the car and took off quick, throwing it into 2nd........ to my suprise again 2nd was there. it seems if i drive the car normal i have no 2nd nor 4th but if i give it a fang all gears are normal (but they do seem out of place).
Re: where did 2nd gear go? Mon, 21 March 2005 05:05 Go to previous messageGo to next message
LOL, maybe you bent the shifter or the mechanism Wink
time2play
On Probation
February 2005
Re: where did 2nd gear go? Mon, 21 March 2005 05:08 Go to previous messageGo to next message
ewwww that dusnt sound to nice, we noticed that when u put the car in 1st (handbrake up) and mock taking off the engine jumps like a pro being offered $100 for her skills.
is there any way i can check the shifter or mechanism, oh and i forgot the small detail that when it happened (last nite) i was giving a touch of a fang.
xolent
Re: where did 2nd gear go? Mon, 21 March 2005 05:10 Go to previous messageGo to next message
mick wrote on Mon, 21 March 2005 01:55
holy shit? i've been driving my car, and everytime i reverse, there's always gear crunching?
uh oh?
time2play
On Probation
February 2005
Re: where did 2nd gear go? Mon, 21 March 2005 05:13 Go to previous messageGo to next message
No Message Body
[Updated on: Tue, 22 March 2005 00:28]
Re: where did 2nd gear go? Mon, 21 March 2005 05:29 Go to previous messageGo to next message
you iz da homie wif da massif dong. dem full sik crunchez r wikid Wink
nice way to fuck your gearbox (as you have found out Razz )
time2play
On Probation
February 2005
Re: where did 2nd gear go? Mon, 21 March 2005 05:30 Go to previous messageGo to next message
i bought the car with 2nd and 3rd crunching already, i just make the best of it.
Kyosho
Wollongong
Re: where did 2nd gear go? Mon, 21 March 2005 05:32 Go to previous messageGo to next message
xolent wrote on Mon, 21 March 2005 16:10
uh oh?
Crunching reverse is quite common...
Many cars are built with no synchro on reverse...
And even the ones with synchro, still crunch...
Its the fact that the counter shaft and the gear just don't perfectly line up and are spinning in opposite directions if you go to engage reverse quickly...
Reverse crunch, and even first gear engagement are quite common, ESPECIALLY on older cars
Corona RT142
Campbelltown
Re: where did 2nd gear go? Mon, 21 March 2005 05:33 Go to previous messageGo to next message
i think someone has either been flat shifting and / or trying to chirp thirds.
mk1sc
Re: where did 2nd gear go? Mon, 21 March 2005 06:23 Go to previous messageGo to next message
like everyone says sounds very much like in the cable. the 2 cable is held by a U clip onto a brackets, one of clip of the cable has fallen off or is not clipped on tight/properly. check that first
mick
toowoomba qld
Re: where did 2nd gear go? Mon, 21 March 2005 12:17 Go to previous messageGo to next message
Actually you will find my advice is also right as I learnt it from AUTOMOTIVE WORKSHOP BOOKS. One for my WB Holden and the other for my Camry as for the 91 Corolla having a common "Crunch in reverse" I doubt it as my Camry's from the same ere Rolling Eyes hell even my old ute never crunched when put in reverse. I some how would doubt Toyota would make a better gear box for the Camry and give the Corolla a shitty one. Yes it is common for cars too "crunch" gears. But I was only trying too give some help. and I hate too say it that having a faulty clutch can also cause difficulty gear changing.
mick
toowoomba qld
Re: where did 2nd gear go? Mon, 21 March 2005 12:49 Go to previous messageGo to next message
http://www.autobrakeservice.com.au/clutch_fault_di ag.php
Just some Clutch realted problems and yes having a faulty clutch CAN cause difficutly changing gears .
There can be many reasons for why something fucks up in a car
I will post MORE up when I find more about clutches
time2play
On Probation
February 2005
Re: where did 2nd gear go? Mon, 21 March 2005 13:13 Go to previous messageGo to next message
the funny thing is if u fang it the gears work fine but when u drive normal there is no 2nd and 4th
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: where did 2nd gear go? Mon, 21 March 2005 22:29 Go to previous messageGo to next message
I ONCE HAD A 4 SPEED AND IT HAD NO FIRST OR THIRD (WHEN IN GEAR SAME AS IN NEUTRAL) BUT ALL THE OTHER GEARS INC REVERSE WORKED FINE. WHEN I PULLED THE GEARBOX OUT THE CLUTCH WAS ROOTED, SUPRISED A SMOOTH CLUTCH WORKED AT ALL. HOPE THIS HELPS
time2play
On Probation
February 2005
Re: where did 2nd gear go? Mon, 21 March 2005 23:07 Go to previous messageGo to next message
crikeys, Sad clutch was dun not long ago, im takin 2 a mechanic 2day hopefully it wont be a big probo (im hoping its mounts)
mick
toowoomba qld
Re: where did 2nd gear go? Tue, 22 March 2005 01:15 Go to previous messageGo to next message
I still stand by my method of checking a clutch for correct operation. Nearly 2 years ago the fluid in my hydraulic system was just like mud?? (Previous owner) and I had trouble selcting gears and had even MORE trouble getting reverse, (But reverse worked fine.) I'm not saying you won't get reverse. but it's harder too put it in reverse.
Jorrs
Coffs Harbour
Re: where did 2nd gear go? Tue, 22 March 2005 12:34 Go to previous messageGo to next message
right below 1st usually........ Razz
86DRFT
Rockhampton QLD
Re: where did 2nd gear go? Tue, 22 March 2005 14:01 Go to previous messageGo to next message
skilled drivers dont use the clutch.
Rolling Eyes
mick
toowoomba qld
Re: where did 2nd gear go? Tue, 22 March 2005 14:07 Go to previous messageGo to next message
Jorrs wrote on Tue, 22 March 2005 23:34
In my Holden ute it was above 3rd Razz
time2play
On Probation
February 2005
Re: where did 2nd gear go? Wed, 23 March 2005 05:09 Go to previous message
hey!
we finally cured the problem, turned out to be the gear selector thingy that connects onto the box, a bolt had fallen out Rolling Eyes
$35 all up in costs Razz
Previous Topic:4AGE vs 2TG
Next Topic:Camry jumps out of 2nd gear
Current Time: Thu Oct 22 06:55:16 UTC 2026
Total time taken to generate the page: 0.0066919326782227 seconds
