Toymods » Tech & Conversions » Clutch Master Cylender Problems.....[SOLVED] Pics coming soon :)
Iceman
icon9.gif  Clutch Master Cylender Problems.....[SOLVED] Pics coming soon :) Tue, 22 March 2005 03:42 Go to next message
Ok i've got a 1991 Camry 3sfe. When i use the clutch harshly (ie Rip it into 2nd) it goes all floppy like it's only working off the slave cylender. It sits about 2inches off the floor and won't come back up unless i lift it. Crying or Very Sad
So the clutch "throw" has gone from about 6inches to 2! Sad Surprised
The clutch DEFINATELY is NOT slipping. But i reckon it needs a new master cylinder...
Thoughts anyone??? Crying or Very Sad Confused
[Updated on: Mon, 04 April 2005 10:16]
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: Clutch Master Cylender Problems........ Tue, 22 March 2005 03:47 Go to previous messageGo to next message
HAVE YOU BLED THE SYSTEM AND CHECKED FOR LEAKS?
MY UTE HAD A SIMULAR PROB IT WAS A LEAK IN THE SLAVE CYLINDER AND I REPLACED IT ITS ALL GOOD NOW. HOPE THIS HELPS
mick
toowoomba qld
Re: Clutch Master Cylender Problems........ Tue, 22 March 2005 12:15 Go to previous messageGo to next message
81LOWLUX wrote on Tue, 22 March 2005 14:47
I also recomend this as I had a similair problem with my 1989 Camry 3S-FE
What is you clutch fluid like?? is it low?? or is it really muddy looking?? (mine was really dirty looking) I replaced my clutch master cylider when this happened all is fine now
oh and are you having trouble changing gears?? as this is what happened with mine
Is the clutch driven plate worn?? thats another possibilty
but yeah I think it's the master cylinder or slave cylinder sticking myself
ra23celica
Re: Clutch Master Cylender Problems........ Wed, 23 March 2005 13:13 Go to previous messageGo to next message
Penguin walks into the mechanic's workshop, with cream around his beak......
Mechanic says "You've blown a seal mate!"
And the penguin says........."It was an icecream - honest !!!!"
Seriously, you have brake fluid slipping past the seals in either or both the clutch master or slave cylinder. Replace the slave cylinder (its cheaper) and see if that fixes the problem.
If not, rip off the clutch master and have it honed and rekitted.......and stay away from seals on the beach....
Very Happy Very Happy Very Happy
Re: Clutch Master Cylender Problems........ Wed, 23 March 2005 13:14 Go to previous messageGo to next message
sounds like the same symptoms I had when my slave cyl went. I gave it a hard shift to 2nd and the pedal basically stayed on the floor - took a few minutes to come back up. $28 later and a new one is fitted and all is sweet and dandy.
edit: if you get a mate to look under your car as you sit in the car and STOMP the clutch pedal, he will probably see some leakage from the slave cyl if that's what has gone. if not, check for leakage around your master.
[Updated on: Wed, 23 March 2005 13:16]
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: Clutch Master Cylender Problems........ Wed, 23 March 2005 22:22 Go to previous messageGo to next message
GOLD............
Iceman
icon10.gif  Re: Clutch Master Cylender Problems........ Mon, 04 April 2005 10:16 Go to previous message
The other day I decided to try and fix or rather mantain my clutch. I tried flushing the system with new break fluid but it stayed merky. I got back in the car to drive home from my mates and the cluch pedal just hit the floor and didnt come back!!! Surprised
After alot of fooling around i decided to pull out the cylinder to have a look at the piston. There's a spring around the piston whick looks like it's made by welding 2 inter-twined smaller springs together. Anyway this was in about 4 or 5 pieces which fell out everywhere. Yay. Dead clutch! Embarassed Mad
So today i went and go a new master cylender and everything works fine Very Happy Cool It was the broken pieces of spring which made the clutch floppy at the bottom. Whenever i hit the clutch hard they would spread out and prevent the piston from moving the full length or the cylender. Razz
I'll get the pics up soon, they're pretty funny looking back at it now. There's only half the amout of spring in the photo as the rest scattered all over the place...... Laughing
Previous Topic:1GGTE into RA60 celica
Next Topic:Alex Decarlis_10 Second_1ggte_TA22_[Article]
Current Time: Thu Nov 19 17:43:15 UTC 2026
Total time taken to generate the page: 0.0059280395507812 seconds
