Toymods » Tech & Conversions » intercooled turbo BLOW through carby?
toyotadiy
intercooled turbo BLOW through carby? Wed, 29 May 2002 18:52 Go to next message
hi guys,
I was told by USA guy with 22R friend that if I went Weber and swapped shaft seals I could do my desired intercooled turbo blow through carby (instead of non-intercooled turbo draw through regular carby)
I want to use the stock carby, does anyone know how I can modify it to achieve 6psi on the 22R?
If not possible, has anyone in here in Australia upgraded to 32/36 Weber, and can I do it with that setup?
thanks,
Tom.
thetoyman75
Club President
Re: intercooled turbo BLOW through carby? Wed, 29 May 2002 22:09 Go to previous messageGo to next message
Tom,
This is not my field of expertise by any stretch of the imagination but your biggest challenge will be getting a carby that can hold the boost pressure. I am led to beleive the old style SU carb's are a good choice for this.
Hope that helps,
1UZ FTE
Re: intercooled turbo BLOW through carby? Wed, 29 May 2002 22:50 Go to previous messageGo to next message
It looks like that u are trying to keep it as cheap as possible and the fueling system is one of the dear aspects of turboing?
U can blow through the stock carb but u would have to completely seal the carby in a box and have the boost completley surrounding the carby.
Having said this u still will have fueling probs in some spots of the rev range and in the long run prob det an engine, even at low boost settings especially if u like a few revs.
There are webber carbs out there that can have 5-6psi blown through without being in a sealed box as we had one running on a datsun 1600 quite successfully for about a year they are not a side draft item but a downdraft.
Fueling was still aprob in certain rpm and boost areas and fuel leakage from boost was also a prob every couple of months
Having said all this make sure u get the mixture checked with which ever way u go as all blow through systems take a lot of fooling around to get right and i mean alot
hmmm i think that carb is still luying in a mates shed actually
i hope this helps
jamie
[Updated on: Wed, 29 May 2002 22:54]
Re: intercooled turbo BLOW through carby? Thu, 30 May 2002 07:48 Go to previous messageGo to next message
The carbeurettor is a known restriction on 22R's; I'd ditch it pronto if I wanted to get any sort of performance out of a 22R.
And if it was me, I'd be replacing the carb with factory EFI! 22R-E fuel injection is not expensive or hard to come by, and it's a bolt-on affair for your engine. Straight away you eliminate all the hassles you're going to run into with a blow-through setup.
pedroenglish
icon14.gif  Re: intercooled turbo BLOW through carby? Thu, 30 May 2002 08:27 Go to previous messageGo to next message
Turbo guru Hugh McGinnis in his book "Turbochargers" recommends not going blow-thru carby, it looks simpler initially,but you run into too many problems,even apart from the safety issues, creates fuelling probs, even down to collapsing the float!
Draw-thru the carby is actually a lot simpler to do, the carby just thinks its on a much bigger engine! Nod
GAZZAke25
Re: intercooled turbo BLOW through carby? Thu, 30 May 2002 09:17 Go to previous messageGo to next message
If you want to blow through a carby the best ones to do it with that can handle boost are the ones off XE and XF falcons they are a webber ADM they fit on the same adaptor plates as the 32/36 webber. I have seen these used on a few cars and they work really well.
Good luck from Garreth
strutto
Gold Coast
Re: intercooled turbo BLOW through carby? Thu, 30 May 2002 13:05 Go to previous messageGo to next message
The Sigma Turbo and the KB Laser Turbo both ran a Solex "pressurised" carby with their factory blow through setups.
In my experience, with a good EFI fuel pump, these are suitable for up to about 20 psi. Hard to believe? I ran 23psi with factory internals in my Laser. It was thrashed every day for 18 months before the 10 year old motor died (of detonation).
BUT fuel pump choice is critical... with the wrong pump and high boost, the motor will drain the carby bowl dry... Sad
It is certainly not the right way to do it though. It can be difficult to get the mixtures right throughout the rev range.
One of these carby's might be fairly hard to find nowadays too...
Go the EFI... It's much smarter.
Re: intercooled turbo BLOW through carby? Thu, 30 May 2002 13:10 Go to previous messageGo to next message
How hard would it be to inject a 21R-C with 22RE stuff?
toyotadiy
icon11.gif  Re: intercooled turbo BLOW through carby? Fri, 31 May 2002 04:50 Go to previous messageGo to next message
No Message Body
RA28
Re: intercooled turbo BLOW through carby? Fri, 31 May 2002 13:17 Go to previous messageGo to next message
Hey, Yahoo groups (groups.yahoo.com) have blow-through and suck-through turbo email lists. they would know everything you need to know.
just search for them on in yahoo groups.
tim
Re: intercooled turbo BLOW through carby? Sat, 01 June 2002 05:01 Go to previous messageGo to next message
justcallmefrank wrote on Thu, 30 May 2002 11:10 PM
That would be (a) very hard and (b) a total waste of time. Smile
Re: intercooled turbo BLOW through carby? Sat, 01 June 2002 12:35 Go to previous message
Fair enough...its been offered to me before, I wasn't stupid enough to take it up, just curiosity got the better of me Smile
Previous Topic:Sideskirts
Next Topic:Scraping metal noise under GEARBOX
Current Time: Thu Nov 19 19:33:41 UTC 2026
Total time taken to generate the page: 0.031387090682983 seconds
