Toymods » Tech & Conversions » Warped rotors - can they be machined or have to replace?
Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 03:41 Go to next message
Hello, just wanted to find out if warper brake rotors can be machined straight again or if they need to be replaced?
Joel
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 03:45 Go to previous messageGo to next message
depends on how muck meat you have on them and how bad they are, generaly yes.
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 03:47 Go to previous messageGo to next message
depends on how much you have to machine off to bring back to true?
but if the hat/mounting parts have also moved/warped then it might be safer/cheaper to chuck it as you might not get a long life out of it.
rob_RA40
c'town, NSW
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 03:48 Go to previous messageGo to next message
check dba catalogue for minimum thickness specs, talk to brake machinist guy make sure only the friction area is warped and not the inner hubby bit (teknikal termin0l0gy)
chuckster beat me to it, i dunno about his terminology tho Laughing
[Updated on: Wed, 23 March 2005 03:49]
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 04:08 Go to previous messageGo to next message
Razz Laughing
... terminikonolgy is for smart fella's
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 04:21 Go to previous messageGo to next message
haha thanks guys Smile the terminikonolgy helped a lot too.
I'll pull them off next week and drop them into a brake shop to see what can be done.
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 06:04 Go to previous messageGo to next message
Really warped? Question
Usually 'warped' rotors are just due to resin buildup on the rotors. Can be emeried off or a few solid applications of the brakes will suffice. Also certain pad types are prone to dumping resin on rotors *looks in the direction EBC Green stuff*.
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 06:10 Go to previous messageGo to next message
They are pretty warped! If rolling slowly with moderate pressure on the peddal you can feel it slowly sinking down & up. Also up on jack stands when I turn the rotor I can feel it getting tighter.
I brought the brake setup secondhand and it's always been like it. Just been putting up with it but thought it was about time I sorted it out.
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 06:16 Go to previous messageGo to next message
Pulsing could still be due to resin.
Before you get too carried away, check for runoff with a dial indicator. Try mounting the rotor in a different position relative to the hub as this may solve most of your runoff issues (if you have any).
Otherwise machine away. Smile
allencr
tallahassee FL usOFa
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 17:33 Go to previous messageGo to next message
Yes, and much more then most will let you, because the minimum thickness is set by lawyers, not engineers. a thin drum is risky since you're trying to expand it, but a disk/rotor isn't dangerous until it's super thin because it's being compressed.
i think those "minimums" are almost twice what they can be.
i've never seen any "resin" that had the same symptoms and/or didn't disappear when used a little.
Also, try the e-brake! it may be your rears!
[Updated on: Wed, 23 March 2005 17:34]
sonwill
Lara, Vic
February 2005
Re: Warped rotors - can they be machined or have to replace? Wed, 23 March 2005 22:37 Go to previous messageGo to next message
I got some almost new AE82 rotors (6mts old) if they fit.
OldSchoolRolla
January 2005
Re: Warped rotors - can they be machined or have to replace? Thu, 24 March 2005 01:56 Go to previous messageGo to next message
A friend of mine got new pads n a light machine on the rotors......wen he got the car bak the pedal was vibrating up n down bad wen depressing the brakes... so we took it bak n the shop gave them a machine again taking off abit more than the first time.
It was fine for a few months then the pedal started getting that up n down feeling wen braking lightly, id probly b getting new ones if urs are way gone......
TCHOON
Sydney- Sutho Shire &...
Re: Warped rotors - can they be machined or have to replace? Thu, 24 March 2005 10:20 Go to previous messageGo to next message
Article on the myth of warped rotors.
http://www.stoptech.com/whitepapers/warped_rotors_ myth.htm
It would be easy for me to pass off my badly vibrating brakes as 'warped' instead of admitting that I didn't tighten up one of my front wheels properly and it stuffed the rotor.. Embarassed
Tim.
M.W.P.
Rocky Mountains, Canada
Re: Warped rotors - can they be machined or have to replace? Thu, 24 March 2005 13:33 Go to previous message
TCHOON wrote on Thu, 24 March 2005 20:50
Thats an interesting read.
Isnt proof rotors dont warp though.
Still lots of good info in there.
Previous Topic:7m ct26 fitting on GT-4
Next Topic:workshop in vic
Current Time: Thu Oct 29 12:59:11 UTC 2026
Total time taken to generate the page: 0.047116994857788 seconds
