Toymods » Tech & Conversions » Bought a RWD 4a-g, going into an AE86, some questions...
Salad Fingers
Darwin, Australia
March 2005
Bought a RWD 4a-g, going into an AE86, some questions... Wed, 23 March 2005 05:37 Go to next message
howdy all just some quick ones, I have searched but couldn't decypher exactly what the go is...
presumably this rwd 4a-g ive bought comes with a flywheel, not sure about clutch...
I presume I can use the std flywheel no worries what about the clutch? someone said its the same as a 4a-c? true?
Can I use a later model clutch or not? is it needed for a std motor?
Also i'm not sure if ill go the stock computer route or buy an aftermarket one straight away...
if I buy the std comp what sensors are needed appart from the ones on the long block? Just the MAP sensor? can i use one off an AE92 twin cam car? what other map sensors are the same?
Is the factory ECU any good?
Cheers, Nathan.
Re: Bought a RWD 4a-g, going into an AE86, some questions... Wed, 23 March 2005 06:06 Go to previous messageGo to next message
You can use the 4age flywheel, the bigport and smallport had different size flywheels though. I found with my bigport the 4ac clutch fitted fine. But the smallport is slightly larger and would need the clutch suited for that.
There is the map sensor, air temp, coolant temp, cold start thermo switch thing, those are the important ones for the factory ecu.
Make sure you get ignitor etc also.
Factory ECU is fine if the engine is also factory.
Joel
Salad Fingers
Darwin, Australia
March 2005
Re: Bought a RWD 4a-g, going into an AE86, some questions... Wed, 23 March 2005 07:24 Go to previous messageGo to next message
TurboRA28 wrote on Wed, 23 March 2005 17:06
Joel
Ok, where is this situated? is it integral to the dissy? or external?
Anyone have a picture?
Not sure what exactly is comming with the long block, but i'm sure I could find a wreck up here to scavange parts off.
So thats bring me back again to the map sensor, is it car specific? or is it just a generic 1bar toyota sensor?
what about the EFI 4a-fe, do they have any parts in common with the 4a-ge EFI? ie, the said ignitor and what not?
Big T
Re: Bought a RWD 4a-g, going into an AE86, some questions... Sat, 26 March 2005 23:29 Go to previous messageGo to next message
The map sensors are different for different models. The plugs on the loom are not the same so you can't hook them in. I know this is a fact for 86kw blutop and 100kw redtop. I don't know if cutting the plugs and soldering them on would work.
Eddie.
Salad Fingers
Darwin, Australia
March 2005
Re: Bought a RWD 4a-g, going into an AE86, some questions... Sun, 27 March 2005 06:15 Go to previous messageGo to next message
Ok cool...
I will be making a custom wiring loom anyway...
It would be really handy if the map sensor from the 4a-fe engine had the same output as the AE86 map sensor... no one knows?
surely they are just 'normal' 0-5v 1bar map sensors?
shinybluesteel
melbourne
Re: Bought a RWD 4a-g, going into an AE86, some questions... Sun, 27 March 2005 06:31 Go to previous messageGo to next message
as far as i know, any 5 volt MAP sensor should work, all they do is go from "vacuum" to atmospheric pressure.
rthy
Melbourne - NthSubs
Re: Bought a RWD 4a-g, going into an AE86, some questions... Sun, 27 March 2005 12:59 Go to previous messageGo to next message
got pics or diagrams of these? also looking for a diagram for the throttle body for the blue top bigport
the 4age manuals dont go into much details Confused
shinybluesteel
melbourne
Re: Bought a RWD 4a-g, going into an AE86, some questions... Sun, 27 March 2005 13:09 Go to previous messageGo to next message
dont need air temp, dont need thermo switch because you dont nee the cold start injector.
to run at least, not sure how much worse it will run without these bits
rthy
Melbourne - NthSubs
Re: Bought a RWD 4a-g, going into an AE86, some questions... Sun, 27 March 2005 13:32 Go to previous messageGo to next message
man, i just wanna scream at my 4age Confused
iv got all those little shits just gotta wire it up... connecting those vacuum hoses and shit but dont know where they go to Confused
then looking at the wire diagrams my head explodes
slydar
Re: Bought a RWD 4a-g, going into an AE86, some questions... Sun, 27 March 2005 23:15 Go to previous messageGo to next message
theres a good chance i can get you a loom/computer/coil and ignitor/map sensor all to suit if you cant source them. PM me.
Salad Fingers
Darwin, Australia
March 2005
Re: Bought a RWD 4a-g, going into an AE86, some questions... Tue, 29 March 2005 00:58 Go to previous messageGo to next message
ok, another question here..
regarding clutches...
The RWD engine can use a 4a-c clutch..
So i'm wanting to buy a beefier clutch to put on the engine while it is out.. What do I order the clutch for? a 4a-c? or a early 4a-g? or a later 4a-g?
what the differences?
slydar
Re: Bought a RWD 4a-g, going into an AE86, some questions... Sat, 09 April 2005 23:25 Go to previous message
you need a 200mm clutch. and a throw out bearing to suit a t50. i can organise you a heavy duty daikin if you like. pm me.
Previous Topic:C52 Gearbox Recondition Cost
Next Topic:AFM maximum measuring capacity calc (flap-type)
Current Time: Thu Nov 19 09:54:24 UTC 2026
Total time taken to generate the page: 0.011054992675781 seconds
