Toymods » Tech & Conversions » stock ignition timing and new cams
Chris Davey
sunny coast, qld
stock ignition timing and new cams Wed, 23 March 2005 10:00 Go to next message
Hi guys,
I am looking into getting some 264deg cams for my 1jz-gte. I have a wolf 3d but the mechanic who installed could not make it do timing as the stock ecu needed the crank angle sensor to make the auto change gears. So my question is: how important is it to be able to change the timing when you are running longer duration cams?
The reason I wasn't that fussed about this was that I have been told by a couple of people that the standard ignition map is very good and there is minimal gains to be had by changing it eg. SIko1j is making big power with stock ecu. Also, it would retain the standard knock sensors.
Thanks in advance
Chris
Chris Davey
sunny coast, qld
Re: stock ignition timing and new cams Thu, 24 March 2005 02:23 Go to previous messageGo to next message
anyone?
Soarer
Wollongong
Re: stock ignition timing and new cams Thu, 24 March 2005 07:05 Go to previous messageGo to next message
http://www.trackdaymedia.com/~manny/Tech%20&%20Diag/2JZ%20cam%20comparison.jpg
Dunno if this'll help... but it shows differences between cam types on a JZ.
Mr DOHC
Re: stock ignition timing and new cams Thu, 24 March 2005 23:55 Go to previous messageGo to next message
i know that on atmo cars u really need a few more degs advance when u put new cams in, cause it basically changes the usable rev range upward.
but i dunno about boosted cars, since timing actually retards when boost comes on,
if u put larger cams in, you will actually lower the dynamic compression of the motor, until you over some that with more boost, ah fuck, i dunno hey Confused
Chris Davey
sunny coast, qld
Re: stock ignition timing and new cams Fri, 25 March 2005 22:11 Go to previous message
thanks guys. I think I will give the cams a miss for a while then. See how it goes with the stockies first.
Chris
Previous Topic:2zzge engine specs
Next Topic:MZ20 Drift Suspension Setup?
Current Time: Fri Nov 20 11:26:48 UTC 2026
Total time taken to generate the page: 0.0059828758239746 seconds
