Toymods » Tech & Conversions » 1998 Levin BZ-G Part Number Help.
Keith K
Ireland
1998 Levin BZ-G Part Number Help. Wed, 23 March 2005 23:18 Go to next message
I am looking for the correct part number for the rear demister switch that is located on the L.H.S. below the indicator stalk switch. I called my local Toyota parts dealer today and asked could he order me one, my car was built in April 1998 but apparently Toyota changed the physical layout or else the pin out of the switch at this time.
Unfortunately the guy at Toyota could not be 100% as to which switch I had and which one I needed to order, or what the differences are between the 2 switches.
Here is all the information I have from my car.
1998 Toyota Levin BZ-G
Model : GF-AE111-ACFZF
Engine : 4A-GE 1587cc
Frame Number : AE111-5056334
Trans-Axle 0160-12A
Plant-Built M12
Can anyone please advise me with the correct part number or tell me if my rear demister switch is the first or later specification one.
The best way I can describe it at the moment is the switch is approximately 2 inches high and half an inch wide in a rectangle shape, and it sits into the dash/console below the indicator stalk on the L.H.S. vertically just beside the small coin holder.
I will get the switch tomorrow and let you know how may pins is on it if that any help.
Thank you for any help given.
Regards,
Keith.
Steve81
Re: 1998 Levin BZ-G Part Number Help. Wed, 23 March 2005 23:32 Go to previous messageGo to next message
The part number is 84790-13020. There is only one switch to suit your car. If you need any help let me know.
Cheers Steve.
Keith K
Ireland
Re: 1998 Levin BZ-G Part Number Help. Thu, 24 March 2005 21:52 Go to previous messageGo to next message
Steve81 wrote on Wed, 23 March 2005 23:32
Cheers Steve.
I taught it was strange myself the Toyota dealer telling me that as my car was built in April 1998 apparently Toyota changed the physical layout or else the pin out of the switch at this time.
I just want to be 100% sure on the correct one before ordering it, here is as much detail as I can give you on my switch at the moment if it sounds like the one you have given me the part number for please let me know.
I mistakenly wrote last night that my rear demister switch was on the LHS of the driver’s wheel under the indicators stalk, when it is in fact on the RHS of the steering wheel under the light stalk.
I looked at the switch today and the pin out is 4 pins in total "depending on which way you hold the switch it looks like this" pin number 1 is in the top right hand corner with pin number 2 to its right then the third pin is directly under the second pin then a gap then the fourth pin down the bottom.
I will get pictures of the switch tomorrow post them.
Thanks very much for the help.
Keith K
Ireland
Re: 1998 Levin BZ-G Part Number Help. Sun, 27 March 2005 09:23 Go to previous messageGo to next message
Here are the Pictures I could get over the weekend the quality may not be the best as they were taken on a camera phone.
But they may help you decide which is the correct part number I need for this switch.
Pic of block connector that switch goes into
http://tinypic.com/2d5st0
Pic Of Switch Pin Out
http://tinypic.com/2d5t9k
Side View Of Switch
http://tinypic.com/2d5tes
Front Of switch
http://tinypic.com/2d5thy
Location Of Switch On Dash
http://tinypic.com/2d6dyf
Thanks for any help given.
Keith K
Ireland
icon5.gif  Re: 1998 Levin BZ-G Part Number Help. Mon, 28 March 2005 17:07 Go to previous messageGo to next message
Cheers Steve.
Steve can you or anyone please confirm for sure if the part number you gave me above is the correct one when you look at the pictures I have posted.
Keith K
Ireland
icon5.gif  Re: 1998 Levin BZ-G Part Number Help. Tue, 29 March 2005 20:58 Go to previous messageGo to next message
Bump
Keith K
Ireland
icon5.gif  Re: 1998 Levin BZ-G Part Number Help. Thu, 31 March 2005 20:02 Go to previous messageGo to next message
Confused Help Please Anyone
KinLoud
Hamilton, NZ
Re: 1998 Levin BZ-G Part Number Help. Thu, 31 March 2005 23:38 Go to previous messageGo to next message
Email Warrick - he is a resident Toyspeed parts Guru. He should be able to help you with part numbers and probably be able to supply the part as well.
http://forums.toyspeed.org.nz/viewtopic.php?t=1356 8
warwick.parts@bowater.toyota.co.nz
Ken
Hamilton
New Zealand
Keith K
Ireland
Re: 1998 Levin BZ-G Part Number Help. Fri, 01 April 2005 09:29 Go to previous message
Thanks Very much Ken.
KinLoud wrote on Fri, 01 April 2005 00:38
Ken
Hamilton
New Zealand
Previous Topic:1977 ke30 needs more power!!!!
Next Topic:Mx62 stereo wiring
Current Time: Fri Nov 20 18:09:27 UTC 2026
Total time taken to generate the page: 0.0072979927062988 seconds
