Toymods » Tech & Conversions » how do i remove the centre caps on a disc hub?
teh_transformer
February 2005
how do i remove the centre caps on a disc hub? Thu, 24 March 2005 07:00 Go to next message
KE70 Corolla.
how do i get those axle hub caps off?
i cant figure out how to pry them off... :S
Joshstix
Toymods Vice President
Re: how do i remove the centre caps on a disc hub? Thu, 24 March 2005 07:06 Go to previous messageGo to next message
Gentle persuasion with a large hammer tends to work for me. That's if a screw driver under the ridge at the bottom doesn't work.
Be prepared to find some new ones though.
teh_transformer
February 2005
Re: how do i remove the centre caps on a disc hub? Thu, 24 March 2005 07:07 Go to previous messageGo to next message
will it be ok without them for just under a week? everything is closed for easter Sad
ninja_86
ADL
January 2005
Re: how do i remove the centre caps on a disc hub? Thu, 24 March 2005 07:22 Go to previous message
wouldnt suggest driving around with out it on as it leaves the bearing in the open dirt dust and water can and will get in there screwing up your bearing....you usually can manage to get them off with out screwing them up to bad.....just get a smaller flat head screw driver between the cap and the hub and hit the screw driver with a hammer to force the cap out...keep doing it and it will work itself out...
Previous Topic:does any 2t / 3t vrs gasket set parts work with a 3t-gteu ?
Next Topic:Product No. for SC14 Supercharger Oil - 1G S/Charger
Current Time: Thu Oct 29 14:48:12 UTC 2026
Total time taken to generate the page: 0.023037195205688 seconds
