Toymods » Tech & Conversions » What would be the best performance from N/A 4AGE
Youngy
Eskilstuna, Sweden
What would be the best performance from N/A 4AGE Sat, 09 November 2002 08:38 Go to next message
Hello all,
I just thought I would add to some issue that have been talked about a bit on this forum.
If you spent the money (you have to pay to play I was once told) on an N/A 4AGE what would be the most you could expect in terms of power at the REAR WHEELS (not flywheel power).
For example a 4AGE with the following, would make what:-
* high compression piston kit
* 272 and 264 cams
* valve spring set and stage one port job (like Eds work)
* adjustable cam pulleys
* nice extractors, or standard as they are still good
* Quad throttles off 20v
* lighter flywheel
* some AFM computer to run the shit (Autronic seems to be a nice choice)
This is just theoretical mind, but I have only heard rumours about power etc, people don't seem to want to be forthcoming.
Cheers.
[Updated on: Mon, 11 November 2002 11:57]
Bugman
Re: What would be the best performance from N/A 4AGE Sat, 09 November 2002 08:41 Go to previous messageGo to next message
Bill Sherwoods page is the most entensive source of turning a stocker 4a-ge into an un streetable monster 4a.
check it out, I'm at work so I dont have the page, something like www.billzilla.com.au
Bugman
Re: What would be the best performance from N/A 4AGE Sat, 09 November 2002 08:44 Go to previous messageGo to next message
found it with a simple search,
http://www.billzill.org
froodogs
Perth, WA
Re: What would be the best performance from N/A 4AGE Mon, 11 November 2002 00:39 Go to previous messageGo to next message
it all depends on your idea of what's streetable i guess. if you're happy to have it borderline undriveable, and needing rebuilding/work all the time, formula atlantic spec would be 'interesting' but a total pain in the ass.
i've seen people around the place claiming up to 140-150rwkw on a setup like the one you've described, which is pretty much what i'm trying to put together eventually.
talk to bill sherwood and 1bam777 (both on these forums) both of whom have very powerful n/a 4age's.
._T_.
Re: What would be the best performance from N/A 4AGE Mon, 11 November 2002 01:42 Go to previous messageGo to next message
from my experience playing with 4age's you will never get 140rwkw out of a n/a 4age - you might come very close with a formula atlantic engine, but that can not be called streetable. for around $15k you can buy a second-hand atlantic engine(reco) ....
the setup you have proposed will most likely make around 100kw at the wheels (depends on your rpm too!) - i don't know whether you are planning on using a small or big port head, and what lift the cams will be. ditto on the c/r.
T
Grega
melbourne.victoria.austra...
Re: What would be the best performance from N/A 4AGE Mon, 11 November 2002 02:39 Go to previous messageGo to next message
methinks 140-150rwkw and you're talking about forced induction..
IRA11Y
Club Member
Re: What would be the best performance from N/A 4AGE Mon, 11 November 2002 05:26 Go to previous messageGo to next message
the new car will be running a similar setup to what you have described except for the fuel management system, ill let you know what you can expect hopefully at the next dyno day if I get time to reassemble the engine and get it back in the car in time
Bill Sherwood
Brisbane / Gold Coast
Re: What would be the best performance from N/A 4AGE Mon, 11 November 2002 08:11 Go to previous messageGo to next message
* 272 and 264 cams
* Quad throttles of 20v
* lighter flywheel
That engine will make about 75kW - 80kW at the wheels. There's no way you'll get 140kW at the wheels from an n/a 4AGE on the road.
froodogs
Perth, WA
Re: What would be the best performance from N/A 4AGE Mon, 11 November 2002 08:16 Go to previous messageGo to next message
sounds like someone's been spinning me vast loads of horseshit... unless they had kw and hp mixed up or something...
*sigh* this is my punishment for being trusting (gullible?) Sad
[Updated on: Mon, 11 November 2002 08:19]
Youngy
Eskilstuna, Sweden
Re: What would be the best performance from N/A 4AGE Mon, 11 November 2002 12:03 Go to previous messageGo to next message
Thanks gents,
T, I would imagine using a lift of 7.9mm both sides a C/R of around 11, not sure of the big/small port deal (which has been talked about to death at Club 4AG), I tend to think that both can work.
Thanks Bill and Bugman for those details, it sounds like an aweful lot of work doesn't it. Which explains my interest in the BEAMS engine threads going on here. Which is the direction you are taking now isn't Bill?
Cheers.
._T_.
Re: What would be the best performance from N/A 4AGE Mon, 11 November 2002 23:34 Go to previous message
the old 4age race motor in the mr2 ran a ported small port head, forged, small journal groupA crank, cosworth forged pistons (10.5:1 - too low c/r for the cams), 320 duration 9.8mm atlantic cams, shim-under buckets, race valve springs, alloy flywheel, 4-1 extractors, quad t/b's & adjustable cam gears. (and programmable engine management, with no emissions stuff)
this motor made 96kw at the wheels, with some odd driveshaft angles (so it probably made about 105kw in an ideal installation)
with a higher c/r bottom end (11.5/12.5:1) it possibly would have made 115kw - and it would have been classed as almost streetable...
if you are running standard lift, ~11:1 cr, factory extractors etc, Bill's estimate will be about spot on.
fyi - the mr2 is now being rebuilt totally spaceframe with a current celica 2zz motor in there.....
T
Previous Topic:4AC Info
Next Topic:3T-GTEU RA-23 Conversion
Current Time: Fri Nov 20 16:00:56 UTC 2026
Total time taken to generate the page: 0.0063018798828125 seconds
