Toymods » Tech & Conversions » What diff is this (AE86)
kane
What diff is this (AE86) Fri, 25 March 2005 03:21 Go to next message
I have recently bought a sprinter with a non standard diff with rear disc brakes, and have no clue as to what it is.
The only info i've been given is that it is out of a Supra, but this may not be true. If it is out of a Supra, that would make it either a F or T correct?
Things to note are that it has Borg Warner cast into the bottom of the housing, and it has 8 bolts facing to the rear of the car. All the diff pics ive dug up on toymods have the bolts on the other side facing the front. What does this mean?
The plate on the back of the diff has this info -
P/N T807 42-103
Ratio 3.89
Ser No 2637
Does this mean anything to anyone?
http://atlas.walagata.com/w/kanem/diff1.jpg
http://atlas.walagata.com/w/kanem/diff2.jpg
ae95
Re: What diff is this (AE86) Fri, 25 March 2005 03:51 Go to previous messageGo to next message
it aint a s or t series thats for sure
Steve-AE86
Ademelaide, SA
Re: What diff is this (AE86) Fri, 25 March 2005 06:06 Go to previous messageGo to next message
more than likely its a r31 skyline diff cut down.
same stud pattern, borg-warner, and that ratio is/was available
Re: What diff is this (AE86) Fri, 25 March 2005 07:06 Go to previous messageGo to next message
It's not a Toyota diff, so yeah probably R31.
rthy
Melbourne - NthSubs
Re: What diff is this (AE86) Fri, 25 March 2005 09:32 Go to previous messageGo to next message
um... its a ke70 diff, i know cos i got one Rolling Eyes
edit: on second thought it looks a bit bigger than a ke70 diff, but that might just be the photos... i get a pic of mine....
[Updated on: Fri, 25 March 2005 09:34]
jesseT18
Castle Hill, Sydney
Re: What diff is this (AE86) Fri, 25 March 2005 09:54 Go to previous messageGo to next message
AFAIK supras are all IRS so that would rule them out, take a pic of the brakes that should help, ill be able to tell you if they are R31 brakes.
commodore diff is another possibility? they run disc borgwarners dont they?
kane
Re: What diff is this (AE86) Fri, 25 March 2005 10:32 Go to previous messageGo to next message
Yeah, you guys might be on to something there about the R31. Any AE86 peeps out there have an R31 diff conversion and can comment?
Also, forgot to mention that it has apparently an open center (havn't actually driven on it yet), and the track is noticeably wider than stock.
Thanks for the help guys, much appreciated.
Re: What diff is this (AE86) Fri, 25 March 2005 10:50 Go to previous messageGo to next message
If that were a T or F series diff there would be 10 or 12 bolts visible in the second photo which attach the carrier to the axle housing. Like I said, it's not a Toyota diff.
JesseT18: Mk1 Supra's came with a live axle, some of which were F series with disc brakes. It's a popular conversion in the US, but less so here where Mk1's are extremely rare.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: What diff is this (AE86) Fri, 25 March 2005 11:43 Go to previous messageGo to next message
give us a pic of the disk brakes/drums, that will tell people for sure.
looks like an R31 diff to me, got one out the back yard atm and looks identical
kane
Re: What diff is this (AE86) Fri, 25 March 2005 21:52 Go to previous messageGo to next message
Unfortunately I won't have a camera back for a couple of days, I'll get brake pics up then.
If I was to pull the back off the diff, would I be able to count the number of splines from inside the housing (with an open center), ie. Can you easily see the axle ends from inside the diff, or will I have to pull the axles out?
takai
Re: What diff is this (AE86) Fri, 25 March 2005 23:27 Go to previous messageGo to next message
Yeah, its an R31 diff, bog warmer, rear loader. Flat section on the bottom of the diff. All points to an R31
jesseT18
Castle Hill, Sydney
Re: What diff is this (AE86) Fri, 25 March 2005 23:33 Go to previous messageGo to next message
R31 brakes-
http://img93.exs.cx/img93/3089/discrear1it.jpg
kane
Re: What diff is this (AE86) Sat, 26 March 2005 03:48 Go to previous messageGo to next message
Alright, I got the wheel off and checked out the brake setup, looks fairly similar to your pic.
The only differences are the caliper is on the back of the disc instead of the top and the caliper doesn't have those fins running down them. But everything else looks pretty much the same shape and style.
Looks like R31 is the answer, thanks all.
takai
Re: What diff is this (AE86) Sat, 26 March 2005 04:42 Go to previous messageGo to next message
Yeah, i was around at simons today, matches up perfectly.
Sam_Q
S.E suberbs, Vic
Re: What diff is this (AE86) Sat, 26 March 2005 22:51 Go to previous messageGo to next message
what I am curious about is your pan-hard rod top mount. There is no way that that is an OEM mount, I am not saying it because it's red but because the toyota one has a lightening hole on the ouside face. Do you know what the story is with it?
kane
Re: What diff is this (AE86) Sun, 27 March 2005 01:11 Go to previous messageGo to next message
Don't know Sam, it all looks pretty factory from underneath. It's the same colour red as the body colour.
Whats a stock one look like, which side is the 'outside face' anyway?
All this work has been done by the previous owners previous owner.
Sam_Q
S.E suberbs, Vic
Re: What diff is this (AE86) Mon, 28 March 2005 07:21 Go to previous messageGo to next message
nope sorry my mistake, i will just go and hide somewhere now
syncro
ireland
Re: What diff is this (AE86) Mon, 28 March 2005 07:41 Go to previous messageGo to next message
looks like a st141 corona diff to me.
kane
Re: What diff is this (AE86) Mon, 28 March 2005 08:02 Go to previous messageGo to next message
Yep, same diff as R31, pintara, VL commo, corona and many others. See, I've learned something!
While I'm at it, can someone answer one of my previous questions; If I take the back cover off the diff, with an open center, could I be able to see and count the number of splines on the axles, or do the axles have to come out?
syncro
ireland
Re: What diff is this (AE86) Mon, 28 March 2005 11:03 Go to previous message
i think there are 23 spline axles if its a pintara or corona and 28 if its a commodore or skyline.
can you tell if the diff casing has been shortened?
Previous Topic:who makes the best rods?
Next Topic:3tgteu issue...
Current Time: Fri Oct 16 00:03:23 UTC 2026
Total time taken to generate the page: 0.085556030273438 seconds
