Toymods » Tech & Conversions » 1jz wierd wire - what is it
1jz wierd wire - what is it Fri, 25 March 2005 04:05 Go to next message
i found a plain black wire coming off the engine block. It comes off near the air conditioning does anyone know what it does??
Bugman
Re: 1jz wierd wire - what is it Fri, 25 March 2005 04:11 Go to previous messageGo to next message
if it's just connected to the block it'd have to be an earth, surely.
Re: 1jz wierd wire - what is it Fri, 25 March 2005 09:05 Go to previous messageGo to next message
i would assume so, but tehre'[s already a big fuckoff earth strap for that, and ths one doesn't bolt to the block like most earth leads, it has it's own plug... and I cant get my head between the air-con and block to see if it's just attached to the block or actually goes anywhere interesting.
Re: 1jz wierd wire - what is it Fri, 25 March 2005 09:12 Go to previous messageGo to next message
Most likely aircon.
Could be aircon earth, could be the switch for clutch on/off.
Re: 1jz wierd wire - what is it Fri, 25 March 2005 09:28 Go to previous messageGo to next message
switch sounds most likely... maybe I wont chop it off then... I plan to hook the aircon up at some stage.
EvilJack
Sutho/Hills NSW
Re: 1jz wierd wire - what is it Fri, 25 March 2005 09:31 Go to previous messageGo to next message
can you get a pic of its location?
i have air con hooked up, might be able to locate
do you know what the plug looks like? and or colours of wires?
M.W.P.
Rocky Mountains, Canada
Re: 1jz wierd wire - what is it Sat, 26 March 2005 04:15 Go to previous messageGo to next message
If it plugs directly onto the block, it wont be anything to do with aircon.
Oil pressure sensor perhaps?
Re: 1jz wierd wire - what is it Sat, 26 March 2005 04:27 Go to previous message
as I said, I cant see where it goes exactly, as it's under the inlet manifold between the air-con and the block.
it's not plugged in, everything except the aircon is working, so it's not crucial Smile
Previous Topic:adjustable cam gears
Next Topic:18r Intermitent Backfire
Current Time: Fri Nov 20 16:01:01 UTC 2026
Total time taken to generate the page: 0.011162996292114 seconds
