Toymods » Tech & Conversions » How to change brake pads? (TA22)
catch_22
Melb
icon5.gif  How to change brake pads? (TA22) Fri, 25 March 2005 08:20 Go to next message
Hi people, I have used the search and cannot find out any threads on how to change brake pads over on a TA22 celica. So I have to post this thread... Can anyone explain the process in getting the pad out of the calliper? any help would be great.
This is for a TA22 celica BTW... Thanks.
styler
Re: How to change brake pads? (TA22) Fri, 25 March 2005 09:59 Go to previous messageGo to next message
well most older cars its remove pins and slide bolts/slide pads,
slide pads out, and that should be it. newer cars can be a bit harder but its pretty simple to do, then bleed afterwards and condition the pads with some driving as recommended
catch_22
Melb
Re: How to change brake pads? (TA22) Fri, 25 March 2005 11:20 Go to previous messageGo to next message
Ok, I saw some pins in the calliper area... I'll give it a go. Thanks for the help mate.
Dale_ta22
Forster NSW
Re: How to change brake pads? (TA22) Fri, 25 March 2005 12:02 Go to previous message
Yep, remove the pins from the silders, slide them out and then I think there's another spring type thing to remove before you get the pads out, make note of which way the springy things come out too, when you go to put the sliders back in, it won't work unless they are the correct way around.
Previous Topic:RT142 (22RE) - which timing chain?
Next Topic:coil overs
Current Time: Fri Nov 20 11:13:28 UTC 2026
Total time taken to generate the page: 0.0053489208221436 seconds
