Toymods » Tech & Conversions » ignition Maps of aftermarket comps on 4aGe...
barbel
ignition Maps of aftermarket comps on 4aGe... Sat, 09 November 2002 11:57 Go to next message
Was wondering if anyone has handy some of there settings on aftermarket computers running on 4age's.
i'm just curious as to whether my car is gettin enuff ignition advance as it doesnt seem to go that good, and it's a fresh motor...
just doesnt sound like its workin,
5KinKP60
Finland
Re: ignition Maps of aftermarket comps on 4aGe... Sat, 09 November 2002 23:37 Go to previous messageGo to next message
Can't help you with partial throttle openings.
In a race trim about 14º to 18º advance at idle. About 32º of total max advance by 3500-3700rpm. All this with wide open throttle. (This was just a very rough guide indeed.)
Less 'racy' cam and street tune benefits from having partial throttle opening ignition management sorted out. Makes more power, is more economical, engine does not hesitate to throttle usage.
Have the problems sorted out on a chassis dyno. Even if they cannot tune it right, they should be able to tell you just how many degrees your ignition is off from ideal advance prorgression curve. (This in a case you have say a distributor dizzy bolted on).
This is kinda reversed engineering, but it's one way to get a grip on problems your engine has.
At least after such dyno session you have the answers to make your engine work well.
-A.
[Updated on: Sat, 09 November 2002 23:38]
barbel
Re: ignition Maps of aftermarket comps on 4aGe... Sun, 10 November 2002 01:41 Go to previous messageGo to next message
i have had it on a dyno, tuned nicely... runs like a dream but just doesnt seem like it's goin well. i have been munched left right and centre by standard corollas and sprinters. my engine is fairly fresh, rebuilt about 5k ago.
when i check out the map it's at around the 27 mark at around 3500, hits 30 degrees at 5000 and 32 at 6500.
just doesnt seem like it pulls down low, like a normal 4age. and doesnt rev out nicely, well not quickly like usuall,
Re: ignition Maps of aftermarket comps on 4aGe... Sun, 10 November 2002 01:54 Go to previous messageGo to next message
What diff are you using in your car, maybe that's why it feels a tad breathless?
Also, with my turbo GZE, I found the only way to get any satisfaction with the timing was to do it myself. It starts off around 22, works up to 40 at cruise, and backs off to about 27 under full boost, seems to work fairly well. (remember thats a low comp motor running on LPG though!)
barbel
Re: ignition Maps of aftermarket comps on 4aGe... Sun, 10 November 2002 03:51 Go to previous message
standard diff...
the whole reason i'm askin is because last night, my brother and i drove around for a while and put some more ignition throughout the map. it went better, felt stronger... drove home from gosford(thats where my bro lives) and as soon as i got of the freeway it felt like crap, and when i take off i really need to give a rev to make an power, seem to me like i;ve done the head gasket it as compression is down on the 2,3 cylinders.
as we were driving it while tuning we couldn't hear any pingin at all, and on the freeway was sittin at 4k most of the way, bizarre....
the only thing i can think off is that it wasnt a genuine toyota gasket, i've heard people have problems ith head gaskets which aren't toyota... so i'm gonna try that next,
i can stil drive it and there no knocks or anything, but it goes even crapper... .hehe
Previous Topic:Acid dipping
Next Topic:my porting job - comments ??
Current Time: Fri Nov 20 20:17:15 UTC 2026
Total time taken to generate the page: 0.0054738521575928 seconds
