Toymods » Tech & Conversions » T50, worn bearing?
Ta22lover
February 2005
T50, worn bearing? Fri, 25 March 2005 14:26 Go to next message
Hi
My 22splines T50 box has some slack in the bearing wich holds the axle going to the clutch/flywheel.
is it normalt that this is not totally tight? i can move the axle a little bit in all directions, its not much but its not all tight either.
is this okay, or should i change the bearing, if its possible?
thanks for any answers
Very Happy
allencr
tallahassee FL usOFa
Re: T50, worn bearing? Fri, 25 March 2005 15:24 Go to previous messageGo to next message
how much is "a little bit in all directions"????
2mm/1/8in is about normal and won't be much less then that with a new bearing.
what's the pilot/spigot bearing like/condition? that is what supports the other end.
before it was removed, was there any whirring noise when idling in neutral, that disappeared when the clutch was disengaged/pedal on the floor? that is when that bearing(and the lay/counter shaft) will make noise when wornout. don't confuse its noise with release/throwout bearing noise.
it's called the transmission's input or first motion shaft.
Ta22lover
February 2005
Re: T50, worn bearing? Fri, 25 March 2005 15:30 Go to previous message
on the end of the shaft i would say it moves from buttom to top ca 1cm, i dont know about if it makes noise or the pilot bearing since i never used the box yet and i havent seen the engine it came from..
if the bearing is worn out, is it easy to change?
thanks again
Previous Topic:MZ20 Drift Suspension Setup?
Next Topic:3tgte or 2t/3t
Current Time: Fri Nov 20 10:21:53 UTC 2026
Total time taken to generate the page: 0.0050981044769287 seconds
