Toymods » Tech & Conversions » Recommended Tunning Places in Vic
NERD
Recommended Tunning Places in Vic Sun, 27 March 2005 23:15 Go to next message
Hi all,
Gave a search first but couldn't find too much in Victoria/Melbourne.
I am looking for a good place to Tune my engine (4AGZE). Making a bad note from the exhaust and a little bit of backfiring.
Could anyone recommend a good place in Victoria?
[Updated on: Sun, 27 March 2005 23:16]
Henn
Rosanna, Melb
Re: Recommended Tunning Places in Vic Mon, 28 March 2005 02:43 Go to previous messageGo to next message
If it has the stock ECU there really isn't much "tuning" you can do. It'd be more problem finding and fixing with sensors or the wiring or something.
If you have aftermarket management then just look for who distributes that brand and go and talk to them. You'll soon work out if they have any idea about ZEs.
In any case I have had very good experience with Speed Technology/EFI hardware on Monomeeth Pde in Mitcham. One of the guys there had a ZE Kombi van.
Hen
NERD
Re: Recommended Tunning Places in Vic Tue, 29 March 2005 00:22 Go to previous messageGo to next message
Hey thanks Hen,
Yeh, its E with the black ae92. the ZE is seeming to give me a couple of problems. Im getting the fuel pump checked firstly as i think that is where the main problem is coming from.
At the same time, it is giving a little backfire every now and then and not sounding too good.
Hopefully after getting the fuel pump issue sorted out, i might give Speed Technology a go and see whats going on.
Hopefully irs nothing too major and just as you said, something to do with the sensors or wiring because it does have the standard ECU. But in anycase, thank for the recommendation.
E
b1gb3n
south Melbourne/KL
Re: Recommended Tunning Places in Vic Tue, 29 March 2005 02:55 Go to previous messageGo to next message
backfiring occasionally could be ignition problem?? stupid suggestion but have u check ur sparkplugs?
NERD
Re: Recommended Tunning Places in Vic Tue, 29 March 2005 06:34 Go to previous messageGo to next message
Hey Ben,
Yeh, i changed spark plug no more that 3000km's ago. I got NGK copper ones but i'm going straight to denso iridium ones next service (in 2000km more).
Not exactly sure if it is the plugs, but i wouldnt say so just due to the fact they were recently changed.
Ill head off the Toyospares tomorrow and see what they have to say and ill keep all updated.
Cheers guys
Aust162
Melb, Victoria
Re: Recommended Tunning Places in Vic Tue, 29 March 2005 09:50 Go to previous messageGo to next message
i spoke to matt at toyospares and he told me about a place called Yarra valley fuel injection in bayswater...
NERD
Re: Recommended Tunning Places in Vic Tue, 29 March 2005 11:16 Go to previous messageGo to next message
Hey Aust162,
Did you get your car tuned from there?
If so:-
why did you tune your car?
what was wrong with it?
did you have the standard ECU?
pro_k
Re: Recommended Tunning Places in Vic Tue, 29 March 2005 12:40 Go to previous messageGo to next message
Hey E - It will more than likely be your injectors. Most places will clean them for $25 each if you take them off and take it to them. Amberley Autos in Dandy are very good.
NERD
Re: Recommended Tunning Places in Vic Tue, 29 March 2005 13:53 Go to previous messageGo to next message
-Pro,
Yeh i have heard alot of Amberley Autos. They must be a fairly good place espically given their reputation of what they do (got many referrals to go their for full custom exhaust systems - hopefully mine will be to come soon). I will go either and/or toyospares hopefully tomorrow and get some sort of idea what is behind it.
It didnt seem too bad of a problem when i first purchased the car (as a new full tank of petrol had no signs of the problem), but seemed to have got worse, therefore your suggestion on the injectors could well be a valid one Pro.
Once putting some foot on the "gas" gives it a bit of a jerky and a feeling of the petrol cutting out and then kicking back in (quite a big jerk). Hopefully -touch wood- its not too big of an issue.
Really not too sure if it is a fuel pump issue. Just thought that was behind it. But since it got a little worse after a few months since getting the car, i dont think that is the cause behind it anymore.
Possibly just general wear and tear of injectors(??).
Thanks anyways Pro,
-E
[Updated on: Tue, 29 March 2005 14:07]
b1gb3n
south Melbourne/KL
Re: Recommended Tunning Places in Vic Wed, 30 March 2005 00:49 Go to previous messageGo to next message
E, u can save the trouble of removing ur injectors. i think if u remove them u canot expose it for too long or something like that.
there is a stetoscope thingy, something like the one doctors use to hear ur heartbeat but this is for injector pulse. not sure what its called but i would suggest u try to borrow that thing frm somewhere to check if ur injectors are fine or not before removing them.
i think its more likely to be the pump rather than injector dude. but dont take my word for it
NERD
Re: Recommended Tunning Places in Vic Wed, 30 March 2005 01:32 Go to previous messageGo to next message
Ben - Thanks for the help mate, will look into that once i change the plugs around to the denso iridiums ones (thank god for ebay)
Just popped over to toyospares before and Matt and Troy were helpful as ever. Matt took it for a drive with me and while giving me endless words of wisdom, he definatly said it was a injection issue. He said firstly i should get iridium or platinum plugs instead of the coppers ones currently on them and also check the ignition leads and the ignition pack.
I'll give them all a througher run through hopefully this week and get my plugs changed as soon as they come in.
Matt did tell me it definatly was not a fuel pump issue, which i previously thought it was. Bladdy happy that he ruled out the fuel pump because that could have really dug into my wallet!!
Pramodh, i think you had a fair idea of what was wrong with it just from what i wrote up and your previous experience with the car, so thanks for your advice too!
Also, i did go to Amberley Autos in Dandy; even though they seemed professional as ever (and the chick at the counter - service manager - was hot as Shocked Shocked = go there just for a peep!!) they wanted $75 for a tuning and look through before they even got in the car!
Pretty disappointed with them, but it was probably due to them being pretty busy.
Cool Cool Thumbs up to Toyospares Cool Cool
Cheers guys
-E
[Updated on: Wed, 30 March 2005 01:34]
Aust162
Melb, Victoria
Re: Recommended Tunning Places in Vic Wed, 30 March 2005 03:01 Go to previous message
NERD wrote on Tue, 29 March 2005 21:16
Hey Aust162,
If so:-
well ive had this problem lately where my idle would drop really low when i come to a stop, also the car had no power what so ever in the high revs.they fiddled around with my idle air fuel mixtures and my ignition timing.
the car have a factory sw20 ecu.its going back tomorrow around lunch time for further tinkering,so u might see my car there Smile
Previous Topic:Hilux 5stuf diff to 4stud
Next Topic:quick 5k questions
Current Time: Fri Nov 20 16:16:21 UTC 2026
Total time taken to generate the page: 0.0066750049591064 seconds
