Toymods » Tech & Conversions » 3tgteu issue...
yems
Tauranga, New Zealand
February 2005
3tgteu issue... Mon, 28 March 2005 08:22 Go to next message
a few weeks ago i was giving my car abit of a cane through a back road between the bottom of the kaimais and camebridge.wen i got to the end of the road and started nana'ing it again it started to miss. like not a hard out dropping of a particular cylinder more like a running out of fuel or low spark on all cylinders. at this point the fuel pump was making a funny noise (the high pressure pump that is) and i naturally assumed that the fuel pump was on its last legs. after replacing the fuel pump with a VL comodore pump the problem was fixed. untill saturday nite. was caning it abit, and got about half a kilometre from home and the same old problem came around. started sort of well the same as explained before, running out of fuel or spark and losing power, but then would go away and drive sweet then start running funny again. i havnt tried anything other than the fuel pump to fix the problem.
the engine is a 3tgteu in a ke30 corolla. running a surge tank setup with a lift pump/low pressure pump into the surge tank and a VL commodore high pressure pump from the surge tank into the fuel lines. both pumps and the surge tank are situated in the boot, the lines run under the car and into the engine bay.
im running all standard ECU and knock sensor computer. the only thing different is im running MSD blaster coils (dont kno why i just kinda bought them and thought they would make it faster.. *shrugs shoulders*)
could any of the mentioned be the problem? im leaning towards just going with a full link setup and getting rid of the silly knock control etc if the problem doesnt go away. just wondering if maybe sum1 has come accross this problem before.
cheers for any help, Yems
YelloRolla
On your mum!
Re: 3tgteu issue... Mon, 28 March 2005 10:32 Go to previous messageGo to next message
It sounds like there may be something preventing the fuel flow, like maybe the lift pump (feeding the surge tank) is too small? Could be something floating around in the tank causing trouble OR maybe just the fuel filter has carked it.
Another thing to consider is the coils, if they are getting too hot (like too much dwell or something wrong with their set up OR if they are plain rooted) they will give less spark and this will become progressively worse.
yems
February 2005
Re: 3tgteu issue... Mon, 28 March 2005 10:49 Go to previous messageGo to next message
hrmm yeh thats what i thought at first and wen i replaced the fuel pump it seemed to fix the problem at first. its unlikely that the filters are clogged as they were both brand new 3000ks ago. also the coils were brand new at the same time. the coils are mounted to the opposite side of the engine bay and i have felt them after a hard run and they arent that hot. i dont understand why the problem is so inconsistent.u would think if it was spark related it would b much more consistent. could it b the pump location. its located in the boot lower than the surge tank but higher than the lowest point of the fuel lines. could this b a problem at all with air pocketing?
on a side note, how much are the wolf 3d computers worth in aus? i cant get them in NZ (that i kno of) an the only aftermarket computer we can really get for cheapish is the link computers.
YelloRolla
On your mum!
Re: 3tgteu issue... Mon, 28 March 2005 10:55 Go to previous message
try pulling your tank and cleaning it - it may be something there. It sounds like the set up with the surge tank is o.k. but is it getting enough fuel to the surge tank?
Wolf Ver4 is AUD$1395 with hand controller.
Previous Topic:What diff is this (AE86)
Next Topic:3tgte fly cut pistions???
Current Time: Sat Oct 17 13:36:25 UTC 2026
Total time taken to generate the page: 0.0046441555023193 seconds
