Toymods » Tech & Conversions » 3tgte fly cut pistions???
moussa
melbourne
March 2005
3tgte fly cut pistions??? Mon, 28 March 2005 08:35 Go to next message
i ve got a set of 3tgte turbo pistons for my 2tgue hybird do i still need to fly cut them?
my head is the later one please help?
YelloRolla
On your mum!
Re: 3tgte fly cut pistions??? Mon, 28 March 2005 09:12 Go to previous messageGo to next message
not likely, but they will reduce static compression ratio, you will need to calculate how much because there are different combustion chamber volumes for the 2T G heads.
Your cams will then be pretty much worthless with the new comp ratio (unless you are going to turbo it).
I would double check the amount of clearance that the valves have.
moussa
melbourne
March 2005
Re: 3tgte fly cut pistions??? Mon, 28 March 2005 10:41 Go to previous messageGo to next message
thanks mate and yes it is turbo charged
YelloRolla
On your mum!
Re: 3tgte fly cut pistions??? Mon, 28 March 2005 10:44 Go to previous message
moussa wrote on Mon, 28 March 2005 18:30
i ve got a set of 3tgte pistons half a mill over size do i still need to fly cut them?
please don't ask the same question in different areas, or we will be chasing all over the shop trying to communicate the same information Smile see the answer that I left on your new thread.
Now you say later model head, which number is stamped on the front of the head (to the right hand side of the cover plate)?
Oh and remember valve reliefs are directly related to a) the size of the cams (and their timing) and b) the size of the valves.
Previous Topic:3tgteu issue...
Next Topic:Has anyone installed a headunit into a 1990 ae92 corolla?
Current Time: Sat Oct 17 10:02:33 UTC 2026
Total time taken to generate the page: 0.0057768821716309 seconds
