Toymods » Tech & Conversions » 4AGE ECU Problems and Did the 1986 OZ corolla's come with AFM or MAP??
rollaboy
Coffs
4AGE ECU Problems and Did the 1986 OZ corolla's come with AFM or MAP?? Sun, 10 November 2002 13:30 Go to next message
Is there anyway of testing wether my ECU that runs may 4AGE is not working properly??
As it seems to not pick up voltage drops e.g. when the fan cuts in or when i turn my lights get turned on or fan inside car.
And when it does this at the lights it almost all of the time stalls....espically when hotter then normal???
[Updated on: Mon, 11 November 2002 04:18]
IRA11Y
Club Member
Re: 4AGE ECU Problems Sun, 10 November 2002 20:10 Go to previous messageGo to next message
it wont measure voltage drop it doesent have that feature...what it will measure (if its map) is the manifold pressure drop when the aircon etc kicks in and the load on the engine changes, there should be a vacume line to the A/C idle control valve from the T/B, in a fwd theyre usually mounted in the passenger corner by the bonnet mount. Im not positive if AFM measures the same way but I cant see why not.
The problem you have is more likely due to poor sensors or blocked vacume lines, it happens on the T/B quite a bit where the 2 ports on top of the T/B get gummed up...just pull it off and clean it with some carby cleaner to see if that fixes it then work from there.
rollaboy
Coffs
Re: 4AGE ECU Problems Mon, 11 November 2002 03:21 Go to previous messageGo to next message
IRA11Y wrote on Mon, 11 November 2002 07:10
Thanks heaps,
Yeah its MAP, has no a/c at the moment.
I have changed the oxygen sensor in the exhaust manifold..is there any others???
Yeah at tafe we gave it a quick clean with carby cleaner but didnt take it off so i'll take it off and clean it good.
Should i replace the gaskets??
One other question are the AFM ECU's the same as the MAP ECU's??
Will a ECU from a AFM 4age run my MAP 4age??
Anyone know what came out in the OZ 1986 4age corolla's..AFM or MAP???
Grega
melbourne.victoria.austra...
Re: 4AGE ECU Problems and Did the 1986 OZ corolla's come with AFM or MAP?? Mon, 11 November 2002 19:28 Go to previous messageGo to next message
no an AFM ECU will NOT run a MAP 4AGE........pinouts are different for one.
um, the AUS spec ae82 1986 4AGE Corolla's were MAP dude.
rollaboy
Coffs
Re: 4AGE ECU Problems and Did the 1986 OZ corolla's come with AFM or MAP?? Fri, 22 November 2002 01:41 Go to previous message
OK i cleaned the T/B the other week did sh*t all.
Its really starting to piss me off when i stalls.
My start motor is almost dead to so some times when it stalls i have to get out with a metal bar or socket ex.. and wack the starter motor..Ohhh yeah its did it at the lights Crying or Very Sad ..was kinda funny but .. Smile my mate was driving.
Previous Topic:Tyre shopping
Next Topic:how to tell what spring rating my springs are?
Current Time: Sat Nov 21 06:23:58 UTC 2026
Total time taken to generate the page: 0.0044281482696533 seconds
