Toymods » Tech & Conversions » GZE block FE head
Kr0n1k
Rochester, NY
February 2005
GZE block FE head Mon, 28 March 2005 18:31 Go to next message
Does this work? What will the compression ratio be? Cams for GE head will or will not work? Will 7MGTE injectors work in the 4A fuel rail? (remembering reading something about this before but unsure). Building a turbo motor and would like to keep costs to a minimum since I don't plan on running more than 10psi for a long time (unless the GZE block can withstand more). Any help would be greatly apreciated. Oh, this will be going into an AE101 Geo Prizm / Toyota Corolla.
Kr0n1k
Rochester, NY
February 2005
Re: GZE block FE head Fri, 01 April 2005 16:15 Go to previous messageGo to next message
*bumpity bump* 4AGZE Block 4AFE Head? Works or not?
the dayo
Re: GZE block FE head Sat, 02 April 2005 01:34 Go to previous messageGo to next message
i wouldn't think it would be the best, FE have a a single driven cam that is connected to the other by a gear, so the gze cams would not fit in. if you could get a whole gze thats your best bet, or even get the block and look for a GE head at a wreckers.
i also think that the inlet and exhaust ports on the FE a smaller than the GE, as th "G" in 4AGE stands for "sportier model"
the GZE block can run way more than 10psi, i ran a turbo set up on a stock silvertop 20V running 7psi and its still running a year later.
Johnny
Sydney, OZ
Re: GZE block FE head Sun, 03 April 2005 02:54 Go to previous messageGo to next message
Just put a Whole GZE in. There are practically Zero performance parts for an FE ie Cams, etc just because they aren't considered a performance engine! No, GE cams can't fit..
Kr0n1k
Rochester, NY
February 2005
Re: GZE block FE head Sat, 16 April 2005 00:19 Go to previous messageGo to next message
I was hoping to get away with just the block. If I do put a whole GZE in, I won't be able to use my alternator or other acsessories, correct?
Re: GZE block FE head Sat, 16 April 2005 13:58 Go to previous messageGo to next message
Alternator doesn't bolt to the head Very Happy
berad
Re: GZE block FE head Sat, 16 April 2005 15:37 Go to previous messageGo to next message
who cares about the alternator if ur just worried about that fitting on u shouldnt be putting that head on it the "fe" head wasnt designed to be a performance engine/head Razz theres plenty of alternators that will fit
flyinwall
Toowoomba
March 2005
Re: GZE block FE head Sun, 17 April 2005 06:03 Go to previous messageGo to next message
actually the 'G' denoted wide head twin cam and the 'F' denotes narrow head twin cam
EldarO
Perth, WA
Re: GZE block FE head Sun, 17 April 2005 07:26 Go to previous messageGo to next message
G = Great
F = Fucking shitty.
F is an economical design, they werent made for anything but commuter cars.
G, however, well... take a look in members rides Smile
Eldar.O.
flyinwall
Toowoomba
March 2005
Re: GZE block FE head Mon, 18 April 2005 06:34 Go to previous messageGo to next message
my old 1991 seca with the standard 4A-FE would take on almost anything and i only had it to 180km/h and it wanted to keep going (but i ran out of road)
ke382TG
Re: GZE block FE head Mon, 18 April 2005 06:53 Go to previous message
We can draw 3 conclusions from this post
1. There are not many quick cars in Toowoomba if a 4AFE powered seca was "taking them on".
2. "i only had it to 180km/h and it wanted to keep going (but i ran out of road)" this would take approximately 25 seconds and a f$%king long road. Please don't do this again as the seca was never designed for this and I can guarantee IT didn't want to keep going Rolling Eyes
3. The 4AFE is ghey.
To the original topic:
Quote:
Does this work?
Maybe but why would you do it?
They work in a 4AGE and 4AGZE fuel rail
It can withstand much more.
Just do what others have said and use a complete 4AGZE, building up a mongrel heap of crap will only end in tears and cost twice as much in the long run. Save some more, do it properly and do it once.
I am unclear on the actual reason for you wanting to use an FE head as I can't see any logical reason to do it???????
[Updated on: Mon, 18 April 2005 06:55]
Previous Topic:another diff question
Next Topic:4age diagnosis (pics included) what is the culprit?
Current Time: Sat Oct 31 21:50:42 UTC 2026
Total time taken to generate the page: 0.0050768852233887 seconds
