Toymods » Tech & Conversions » 212mm and 200mm 4AGE flywheel. *URGENT*
Rallystanza
icon4.gif  212mm and 200mm 4AGE flywheel. *URGENT* Tue, 29 March 2005 00:29 Go to next message
Hey guys i need a quick and accurate response here...
I am getting a 212mm clutch made up to suit a 212mm flywheel and the clutch guy needs to know what the difference is in the 212 an 200mm flywheel.
Are the physical dimensions of the flywheel the same. I mean is the outermost diameter of the flywheel where the ring gear is, is that the same measurement between the two?
As i dont yet have the 212mm fly i cant tell him what to do.
Any what did the 212mm flywheel and clutch come on/in?
HELP PLEASE!
Jezza
[Updated on: Tue, 29 March 2005 00:43]
fatmr2
Re: 212mm and 200mm 4AGE flywheel. *URGENT* Tue, 29 March 2005 00:46 Go to previous messageGo to next message
The flywheel from my ge and gze are totally different. The gze one is the larger of the two.
I would wait till you get the flywheel.
Rallystanza
Re: 212mm and 200mm 4AGE flywheel. *URGENT* Tue, 29 March 2005 00:50 Go to previous messageGo to next message
I was thinking the same thing man.
I told him that the flwheel and clutch came in an ae92 100kw motor and he then said that that was a 215mm flywheel and clutch. I dont get it now!
I have told him to put it all on hold until i ge tthe flywheel anyway, but now im curious as to the size of it all...?
Jezza
takai
Re: 212mm and 200mm 4AGE flywheel. *URGENT* Tue, 29 March 2005 02:18 Go to previous messageGo to next message
The AE92 Smallport GE had a 212mm clutch. Look it up in the Exedy cattledog, its 212mm. The AE86/82 Bigports had a 200mm clutch.
While the E-series boxes had either a 220 or 225mm clutch, cant remember. But its totally wrong for the GE
The ring gear is the same size.
Rallystanza
Re: 212mm and 200mm 4AGE flywheel. *URGENT* Tue, 29 March 2005 02:27 Go to previous messageGo to next message
Thanks heaps Takai. Once again youve helped me out.
Cheers mate,
Jezza
Re: 212mm and 200mm 4AGE flywheel. *URGENT* Tue, 29 March 2005 04:06 Go to previous messageGo to next message
with the 4agze clutches, there are two types:
# 225mm - most common
# 230mm - rare
with these two, the PCD for the pressure plate is also different (the 230mm being 2.5mm larger).
NOTE: no one who dealt with Daiken Exedy clutches was able to supply a 230mm 4agze clutch, and Daiken dont even list one in their catalogues.
takai
Re: 212mm and 200mm 4AGE flywheel. *URGENT* Tue, 29 March 2005 05:49 Go to previous message
When i built my GZE i was able to get a 230mm Exedy clutch, and pressure plate. Sure it would have cost $650 but i was able to get it. As it was i got the 3puck button clutch and sourced a 2nd hand TRD plate. All up $240
Previous Topic:2pac paints
Next Topic:Turbo shaft stiff
Current Time: Sat Sep 12 17:47:28 UTC 2026
Total time taken to generate the page: 0.058803796768188 seconds
