Toymods » Tech & Conversions » 1g diag light (I've searched)
willwal98
Toowoomba
1g diag light (I've searched) Tue, 29 March 2005 04:25 Go to next message
Anyone know where the 1g engine diagnostic light normally joins to on the ECU? I want to run a test to make sure everything is fine.I have a feeling the temp signal is not gettign back to the ECU but I have no test light. Also where do those two pins go to on the ECU because i'm not sure if I have those either. It's a gen 3 1g-gte in an RA28.
Re: 1g diag light (I've searched) Tue, 29 March 2005 06:19 Go to previous messageGo to next message
Gen2 or 3? Basically, check the wiring diagram for your ECU for the "check engine light" pin, give 12V to one side of your light and the earth it via that pin on ECU.
Re: 1g diag light (I've searched) Tue, 29 March 2005 06:20 Go to previous messageGo to next message
Haha, helps if I read properly, check a Gen3 wiring diagram Wink
Re: 1g diag light (I've searched) Tue, 29 March 2005 06:53 Go to previous messageGo to next message
the warning light itself is typically on the "BODY" plug of the ECU with the label W.
Connect this to one side of a low power 12V globe or LED, and the other side of the globe to ignition.
Do you have the diagnostic port wired up in your car?
ChuckLandwehr
Re: 1g diag light (I've searched) Tue, 29 March 2005 08:13 Go to previous messageGo to next message
Alternatively, bridge your diagnostic plug terminals with a light bulb, instead of just a paper clip. The bulb will flash the codes!
cheers Chuck.
willwal98
Toowoomba
Re: 1g diag light (I've searched) Tue, 29 March 2005 08:34 Go to previous messageGo to next message
thanks guys, been a big help. I'll have a look when I get a chance and see what I can find. Thanks again
willwal98
Toowoomba
Re: 1g diag light (I've searched) Sat, 02 April 2005 08:43 Go to previous messageGo to next message
does it need to be connected before the key is on? And does the engine need to be running?
I connected it up between the ECU power pin and the diagnostic pin and it just stays on, no blinking at all. Does this mean anything?
Also what's likely to happen if you have multiple codes, does it just do them in sequence or does it just show one?
HyDrA
Adelaide, SA
Re: 1g diag light (I've searched) Sat, 02 April 2005 23:44 Go to previous messageGo to next message
It's just easier to do it before turning the key... that way you wont miss the codes! Smile (yes, i've tried it)
willwal98
Toowoomba
Re: 1g diag light (I've searched) Sun, 03 April 2005 03:19 Go to previous messageGo to next message
whats it mean when it stays on?
HyDrA
Adelaide, SA
Re: 1g diag light (I've searched) Sun, 03 April 2005 08:42 Go to previous messageGo to next message
See if the engine is still there Razz
It should flash constantly if everything is ok, and flash certain amounts to represent numbers, which will be the error codes. If it's always on, you either haven't done it right or there is something fucked with the ECU afaik.
willwal98
Toowoomba
Re: 1g diag light (I've searched) Sun, 03 April 2005 12:11 Go to previous message
Checked, engine is in place Very Happy
I'm pretty sure I have the right wire, yellow with a red stripe and on the same plug as the main ECU power ect. Engine runs pretty good, no problems with it but it seems to run a little rich, just wanted to check the ECU is getting things like water temp signal properly. Might just go through all the sensors with a multimeter and check there connection with the ECU.
Previous Topic:No power steering assistance on MX73 1JZ
Next Topic:Stock 1JZ power.
Current Time: Sat Nov 21 14:36:44 UTC 2026
Total time taken to generate the page: 0.0045609474182129 seconds
