Toymods » Tech & Conversions » Hilux diff - corolla?
boofis
MELBOURNE
Hilux diff - corolla? Tue, 29 March 2005 06:13 Go to next message
Hey
What would have to be done to put a hilux diff in a corolla with an LSD centre? Also what would be a good ratio is it? Like 4:3? I'm after mostly acceleration.
Troy!
stradlater
Arthurs Creek, Victoria
Re: Hilux diff - corolla? Tue, 29 March 2005 06:19 Go to previous messageGo to next message
Well, you'd have to modify the mounts and so forth to fit a hilux diff inside a corolla. And I'm guessing you'll have to shorten it, becuase I greatly doubt there's any hilux diff as short as a corolla. But you may not have to shorten much.
The ratio's you'll commonly get are 4.1:1 I think it is. Depends though, that's the common open wheeler one. The LSD ones are way different in the ratios.
EMP-2TG
Carlingford, Sydney
Re: Hilux diff - corolla? Tue, 29 March 2005 10:00 Go to previous messageGo to next message
you need the RN25-27 diff, it will fit without cutting it down, u will then need to cut and move the spring seats out 25mm each side, you will also need to make new handbrake cables up, which will be one of the harder parts of the job...
you will need to get the rear hiulx uni welded into your tailshaft and the tailshaft shortend
if you want 4.3LSD you will need to get that center out of a later model hulix then get the ends of the (RN27) axels machined down so it doesnt all bind together when you do it up
all in all its not that hard, we put mine in over a weekend
boofis
MELBOURNE
Re: Hilux diff - corolla? Tue, 29 March 2005 10:30 Go to previous messageGo to next message
Thanks for the reply dude! I"ll be doing that once I've worked the motor. DO you reckon 4:3, is a good setup for acceleration? Or any other recommendations!
Troy
EMP-2TG
Carlingford, Sydney
Re: Hilux diff - corolla? Tue, 29 March 2005 10:47 Go to previous messageGo to next message
well what motor are you running in it?
if its an N/A motor id run like a 4.5 or 4.8
if its turbo id ran 4.3 or 4.1
all depends on what your doing to it
ra23celica
Re: Hilux diff - corolla? Wed, 30 March 2005 01:40 Go to previous messageGo to next message
Josh,
When you say, 'get the RN27 axles machined down', what do you mean exactly ? Is it 5mm taken off the splined end of each axle, that goes into the diff centre?
Thanks,
Mitch.
EMP-2TG wrote on Tue, 29 March 2005 20:00
[Updated on: Wed, 30 March 2005 01:41]
TE72_Turbo
Re: Hilux diff - corolla? Wed, 30 March 2005 02:31 Go to previous messageGo to next message
What model corolla are we talking about here anyway? Confused
You'd do yourself a big favour to be a bit more specific about your current specs, and future aim Cool
EMP-2TG
Carlingford, Sydney
Re: Hilux diff - corolla? Wed, 30 March 2005 07:04 Go to previous messageGo to next message
this is avery good point about what corolla
im talking about ke30-55
and yep 2-3mm off the splined end is enough
boofis
MELBOURNE
Re: Hilux diff - corolla? Wed, 30 March 2005 09:12 Go to previous messageGo to next message
HEy
Ke55 Thats going to be running a 5k with a 4k head hopefully if thats possible for higher compression.
Troy
Re: Hilux diff - corolla? Wed, 30 March 2005 10:06 Go to previous messageGo to next message
Hilux diff is serious overkill. A T series from a Celica would be adequate.
boofis
MELBOURNE
Re: Hilux diff - corolla? Wed, 30 March 2005 10:11 Go to previous messageGo to next message
yeah. NIce as! Would it cost more though? I'll take your advice if thats so!
Troy
EMP-2TG
Carlingford, Sydney
Re: Hilux diff - corolla? Wed, 30 March 2005 13:22 Go to previous message
yeah hilux diff is wwwaaaayyyy overkill...
Previous Topic:Remote booster for ke55 with 2tg
Next Topic:rocker breather losing oil
Current Time: Fri Nov 20 05:59:37 UTC 2026
Total time taken to generate the page: 0.0061919689178467 seconds
