Toymods » Tech & Conversions » ma61 not starting
Thruan
mackay
ma61 not starting Tue, 29 March 2005 08:13 Go to next message
ok guys. got the thing back together, all is good, but no spark, when turing the engine, i have NO spark, key in the on position, turn the dissy by hand it sparks, turn the motor by the key and turn the dissy by hand and ive got no spark. changed th emc from one out of a working (but smashed) supra, still nothing, ran the whole ignition sys off a seprate battery (thought it mite have been a power drain) but still nothing, ive treid everthing i can think of but still cant fix it.... do use have any idea of what it could be?? any help at all, no matter how simple is appreciated.. thanks
HyDrA
Adelaide, SA
Re: ma61 not starting Tue, 29 March 2005 08:18 Go to previous messageGo to next message
So the coil+ignitor is definetly getting power during cranking? Test it on the plug(s) going to the ignitor with a multimeter while cranking.
hamgatan
Re: ma61 not starting Tue, 29 March 2005 08:23 Go to previous messageGo to next message
i used to have a similar problem..
is yours auto?
i used to have an issue where sometimes it would be in P and not start, and i had to fiddle with the stick a bit before it would behave and crank over.. not sure why. maybe give this a go..
Re: ma61 not starting Tue, 29 March 2005 13:15 Go to previous messageGo to next message
There are two circuits feeding power to the ignition coil. One goes via the ballast resistor and provides an 8v power supply for normal running; the other bypasses the resistor and gives the coil a full 12v hit during cranking. It sounds like the cranking circuit is broken, which would explain why you have spark when turning the dizzy by hand but not when cranking.
TRD_Supra
On Probation
Hobart
Re: ma61 not starting Tue, 29 March 2005 22:04 Go to previous message
jesus norbie do u know everything about MA61.. or did secertly work with toyota to create this car ?
Previous Topic:blitz english instructions needed
Next Topic:3t-gte --> Ta22 mount question
Current Time: Fri Nov 20 18:00:01 UTC 2026
Total time taken to generate the page: 0.005497932434082 seconds
