Toymods » Tech & Conversions » MAJOR Brake Problems
Leighp
NY
MAJOR Brake Problems Mon, 11 November 2002 01:02 Go to next message
as the title says, i am having a major brake problem, they seem to go spongy after a while. there is no evidence of leaks anywhere but after about 3 days to a week there is visual signs of brake fluid not being in the resiviour (that holds it). I have blead the breaks from back lft, bk rt, frt lft frt right (in that order) twice and been very careful with how i did it.
This is of major concern to me as i have a rocket 20v and i would like to stop all the time, not just some times
please reply or email me on 4age20v@go.com
Concerned (not that i dislike going fast, it is the slowing that is concerning)
Leigh
Re: MAJOR Brake Problems Mon, 11 November 2002 03:17 Go to previous messageGo to next message
Your brake fluid must be going somewhere! Check again for leaks. Sometimes the master cylinder will leak inside the cabin, so have a good look up there.
Re: MAJOR Brake Problems Mon, 11 November 2002 05:49 Go to previous messageGo to next message
as norbie said.. you've just got to do you typical trouble shooting.
go from your master cylinder all the way through the braking system till you find the leak.. it has to be there.
you can try pumping the brakes a lot to get some of the fluid leaking, and see if you can find where it puddles on the ground (hopefully it's on the ground, and not somewhere on your car)
Chris_RA60
Ballarat
Re: MAJOR Brake Problems Mon, 11 November 2002 05:51 Go to previous messageGo to next message
Try running your fingers under the master cylinder, as it can be hard to see leaks. Also try looking at the paint under the master cylinder, and as brake fluid destroys paint
Re: MAJOR Brake Problems Tue, 12 November 2002 23:54 Go to previous message
Also see if its not filling up the booste with fluid
Previous Topic:86 Corolla
Next Topic:Suitable diffs for AE86
Current Time: Sat Oct 24 09:52:50 UTC 2026
Total time taken to generate the page: 0.0042011737823486 seconds
