Toymods » General Car Talk » st185 GT4 boost sensor
WantaTurbo
st185 GT4 boost sensor Wed, 30 March 2005 00:32 Go to next message
Hey i need a new boost sensor for my car just wondering if i could use a boost sensor off any genII 3SGTE or if it would have to be the boost sensor off a st185. Thanx,
Bill
WantaTurbo
Re: st185 GT4 boost sensor Sun, 03 April 2005 23:30 Go to previous messageGo to next message
anyone?
Re: st185 GT4 boost sensor Mon, 04 April 2005 04:28 Go to previous messageGo to next message
no you cannot.
Gen2 3sgte uses a 2 bar map sensor to drive the boost guage and give the ECU a boost cut signal.
Gen3 3sgte uses a 2.5-3bar (not sure exactly) maps sensor which the ecu uses for sensing engine load.
IE. the two are not compatible.
Joshstix
Toymods Vice President
Re: st185 GT4 boost sensor Mon, 04 April 2005 05:00 Go to previous messageGo to next message
There are two different parts used for Gen 2 map sensors. One has a 12PSI boost cut and the other 17PSI.
I know the ones of the same part number are definately interchangable between MR2 and GT4. I do not know if the different models are interchangable though.
davedave
Re: st185 GT4 boost sensor Mon, 04 April 2005 05:21 Go to previous messageGo to next message
Probably not the greatest idea as you'll be loosing your 'boost cut', but this was suggested to me when I was struggling to find one. It's basically just making something to send a signal to your ECU to say that everything's ok.
JimKing
To carry off this deception, you probably want to use a resistor "bridge". You use two resistors in series wired between ground and the +5v MAP sensor supply. You connect the MAP signal wire to the junction between the two resistors. The junction voltage is proportional to the resistances.
Vj = R2 / (R1 + R2) * 5.0v, assuming R2 is connected to the 5v supply, and R1 is connected to GND.
A two bar map sensor should read about 2.5v at 0.0psi, so if you want to simulate that, then a couple 10k ohm resistors should do.
See if this artwork helps:
.........R1.....................R2
..|---\/\/\/\/\----O----/\/\/\/\/----|
.GND...............Vj...................+5V
..............(to ECU PIM input)
WantaTurbo
Re: st185 GT4 boost sensor Mon, 04 April 2005 05:30 Go to previous message
Thanx guys. So im right in saying that i can use a boost sensor of any 3sgte gen II as long as its one that has the same 12psi boost cut as mine ? eg i could use a mr2 gen II 3sgte boost sensor but not an genII group A 3sgte boost sensor? I think i'll look around for a bit b4 i start making circuits hopefully one will turn up....
[Updated on: Mon, 04 April 2005 05:31]
Previous Topic:Autotecnica Boss Kits and AE86's
Next Topic:For Toyota, Vote Here! RWD? or FWD?
Current Time: Sat Nov 21 03:28:16 UTC 2026
Total time taken to generate the page: 0.030326128005981 seconds
