Toymods » Tech & Conversions » 1 master cylinder VS 2 master cylinders
bubbles
Banned user
Liverpool NSW
1 master cylinder VS 2 master cylinders Wed, 30 March 2005 03:11 Go to next message
Could some one explain what are the benefits of having a separate master cylinder for the rear. Are there any benefits??? Rolling Eyes
setsuna
Re: 1 master cylinder VS 2 master cylinders Wed, 30 March 2005 03:18 Go to previous messageGo to next message
more piston area in 2cysl for greater braking capacity/feel?
... or something? Razz
brake biasing made easy?
not too sure.
I am sticking to one for now Smile
Chris Davey
sunny coast, qld
Re: 1 master cylinder VS 2 master cylinders Wed, 30 March 2005 03:21 Go to previous messageGo to next message
I would think the advantage of having one is a lot less stuffing around setting 2 up.
setsuna
Re: 1 master cylinder VS 2 master cylinders Wed, 30 March 2005 03:24 Go to previous messageGo to next message
hehehehe.
I think so too!
wilbo666
Re: 1 master cylinder VS 2 master cylinders Wed, 30 March 2005 03:57 Go to previous messageGo to next message
With two master cylinders you run a balance bar and can use the balance bar to adjust the brake bias easily (no bias valve)....as far as I'm aware?
Corona RT142
Campbelltown
Re: 1 master cylinder VS 2 master cylinders Wed, 30 March 2005 04:00 Go to previous messageGo to next message
um does this refer to the toyota tandem brakes system ie if one fails you will still maintain some braking through the system that still works this is my understanding anyway.
55gas
canberra
March 2005
Re: 1 master cylinder VS 2 master cylinders Wed, 30 March 2005 04:04 Go to previous messageGo to next message
Bet you've never seen twin master cyl's used with a brake booster.
on a race engine there is not sufficient vacuum to operate a booster.
Using two separate cyl's it is easier to bias, also if you loose one braking circuit you still maintain full pedal feel unlike integral master cylinders.
To operate twin cyl's you would have to customize pedal boxes and remove your booster.
Racing use only.....
earlyrolla
Re: 1 master cylinder VS 2 master cylinders Wed, 30 March 2005 15:14 Go to previous message
Also with running two individual master cylinders and no booster, the internal bore of the master cylinder is smaller than compared to a boosted system so that there is a higher hydraulic gain.
Put really simply, smaller master cylinder bore and larger slave cylinder bore equals more gain. However adequate fluid displacement needs to be taken into account too.
Twin reservoir dual circuit master cylinders are designed if one circuit (front or rear) fails then you still have braking on the remaining circuit.
[Updated on: Wed, 30 March 2005 15:16]
Previous Topic:rwd 4age manifolds(exhaust)
Next Topic:MA70 windscreen fogging
Current Time: Fri Nov 20 05:40:26 UTC 2026
Total time taken to generate the page: 0.038973093032837 seconds
