Toymods » Tech & Conversions » 500cc RX-7 S4 injectors into a GT4 185
JFAllen
Adelaide, South Australia
March 2005
500cc RX-7 S4 injectors into a GT4 185 Wed, 30 March 2005 22:58 Go to next message
while not a huge upgrade in avaliable fuel (40cc's I'm lead to believe) if they will fit I reckon they'll be a worth while upgrade as I can aquire them at an excellent price.
My question is will they fit the standard 185 fuel rail and if not is it possible retro-fit them with little effort.
Jordan
P.S: sorry if this is a repost
..J..
opening a can of whoop ass
Re: 500cc RX-7 S4 injectors into a GT4 185 Thu, 31 March 2005 00:35 Go to previous messageGo to next message
they are in fact 550 cc as i have set of 6 for sale at the moment.
it would most likely require a new fuel rail to be made. 1 metre of fuel rail costs $44. you will need to have it cut to size and drilled for your engine and injector spacing. you will need to have weld on's put onto ech end of the rail for you fuel lines and possibly a modification to the injectors stub where the injectors fire into.
JFAllen
March 2005
Re: 500cc RX-7 S4 injectors into a GT4 185 Thu, 31 March 2005 06:18 Go to previous messageGo to next message
Armed with that infomation, I'm going to leave it in the "too hard / can't be bothered" basket
for your help
Jordan
Joshstix
Toymods Vice President
Re: 500cc RX-7 S4 injectors into a GT4 185 Thu, 31 March 2005 06:51 Go to previous messageGo to next message
On the other hand the injectors out of the Gen 3 3SGTE are a direct fit into the Gen 2 fuel rail and are 550cc injectors.
Classique71
Colac, Victoria
Re: 500cc RX-7 S4 injectors into a GT4 185 Fri, 01 April 2005 00:00 Go to previous messageGo to next message
josh is on the money ..
direct plugin mate - you dont need to change a thing ..
i believe John from importbitz has a fet of 800CC sard sidefeeds which also direct plugin for about 500 dollars for the set
benmeyer
Re: 500cc RX-7 S4 injectors into a GT4 185 Fri, 01 April 2005 04:46 Go to previous messageGo to next message
Would the 205 injectors require a computer upgrade aswell?
Joshstix
Re: 500cc RX-7 S4 injectors into a GT4 185 Fri, 01 April 2005 04:54 Go to previous messageGo to next message
Yes of course increasing the flow through the injectors by 25% will need a change to the management.
Classique71
Colac, Victoria
Re: 500cc RX-7 S4 injectors into a GT4 185 Sat, 02 April 2005 03:38 Go to previous message
correct again - give that man a goold star Smile
something like the haltech / microtech/ wolf EMS setup would be advised if you dont want a all balls out rally machine ( then motec all the way )
get a set if you can - then - if you can wait a bit for management - im going to talk to Wolf soon about a group ECU buy for the club
Previous Topic:What is the Lowest F Series Diff ratio?
Next Topic:Low Revs Cutting Out / Stall (MA70-7MGTE)
Current Time: Fri Nov 20 13:34:40 UTC 2026
Total time taken to generate the page: 0.0060839653015137 seconds
