Toymods » Tech & Conversions » Which Clutch? ASAP!
DanielGVisser
Rockhampton, Queensland
icon4.gif  Which Clutch? ASAP! Thu, 31 March 2005 01:10 Go to next message
Hello,
am using 4a-fe gearbox on a 4a-gze engine. need to know which clutch to order? basically do i order a 4a-fe clutch or do i order a 4a-gze clutch? or are they the same? i have absolutely no idea. All i know is that the gearbox mounts up to the 4a-gze, due to the 4a-fe sharing the same (4a) block.
Any help would be greatly appreciated.
Daniel
Re: Which Clutch? ASAP! Thu, 31 March 2005 01:20 Go to previous messageGo to next message
Depends which frying wheel you use. If you use the GZE one, then (I'm almost certain) you'll need a GZE pressure plate and a different, suitable clutch plate as the input shaft is the smaller size. The 4AF frying wheel won't bolt up the the 4AG (6 vs. 8 bolts)
Another, more sensible, option is to use a GZE box - they're not that hard to find/expensive.
DanielGVisser
Re: Which Clutch? ASAP! Thu, 31 March 2005 01:23 Go to previous message
my gze box that is on there now is ratted and i have to use fe one temporarily. can you point me in the right direction please someone. Will the 4a-fe gearbox fit over the gze flywheel?
do i just get a gze pressure plate with the rest of the clutch kit comprising of fe gear? please help me out asap.
Previous Topic:GZE FWD Gearbox Issues!
Next Topic:UZS151 pin outs
Current Time: Fri Nov 20 07:32:37 UTC 2026
Total time taken to generate the page: 0.0064511299133301 seconds
