Toymods » Tech & Conversions » 7mge-7mgte MX83 conversion and parts requred
MX83Grande
January 2005
7mge-7mgte MX83 conversion and parts requred Thu, 31 March 2005 03:13 Go to next message
Hey guys,
Just wondering if anyone has extensive knowledge or has completed their own conversion of an NA 7M to GTE specs i.e. knows exactly what needs to be changed-eng/trans ECU, eng harness,ignition(C.A.S. twin post coils ness?),manifolds(which will fit which,radiator,injectors or any relevant info.
I know this is far from the ideal way to get power in an MX83 but I think it will be a good temp measure till I can get a 2J conversion together and underway!
I'd rather do it and blow the 7M sky hy then have to pull a perfectly good(haha) 7M out to put the 2J in later.
Also anyone who may have the nessacery parts for this conversion inc manifolds,ECU, CT26 or whatever etc.
Any info would be appreciated!
Cheers.
..J..
opening a can of whoop ass
Re: 7mge-7mgte MX83 conversion and parts requred Thu, 31 March 2005 03:54 Go to previous message
i seen a na 7m converted over with a manifold injectors ecu etc, the na engine didn't last real long. big end bearing went
my advice would be to put that money towards your 2jzgte conversion or go the cheaper option of a 1j as it would probably cost you about the same as turboing the na 7m and it will go for ever.
good luck either way
J
Previous Topic:Edit: 3T bore tolerances
Next Topic:st165 chassis number
Current Time: Fri Nov 20 09:43:42 UTC 2026
Total time taken to generate the page: 0.0051889419555664 seconds
