Toymods » Tech & Conversions » Fuel pressure VSV on 4AGZE
nick.parker
January 2005
Fuel pressure VSV on 4AGZE Thu, 31 March 2005 10:29 Go to next message
Hello,
Can somebody tell me the function of the fuel pressure VSV (vacuum switching valve) connected between the 4AGZE fuel pressure regulator and inlet manifold.
Is it bad under some conditions to use a setup where the manifold is directly connected to the fuel pressure regulator, with no VSV?
Cheers, Nick.
AW11SC
DiZ_
The Eastwood MASSIVE !
Re: Fuel pressure VSV on 4AGZE Thu, 31 March 2005 11:33 Go to previous messageGo to next message
I had the VSV removed on my setup due to aftermarket computer and it worked fine just off direct manifold vacuum.
gearb0x
Re: Fuel pressure VSV on 4AGZE Thu, 31 March 2005 11:58 Go to previous messageGo to next message
according to http://www.mr2sc.com/websites/tech/tccs.htm its just there for afterstart enrichments. Just raises the fuel pressure to add a little fuel, might cause a rough idle or somethign removing it but itll run fine
Adsport
Perth WA
Re: Fuel pressure VSV on 4AGZE Sat, 02 April 2005 04:39 Go to previous messageGo to next message
Mie runs fine with the vsv missing, and very rich.
Re: Fuel pressure VSV on 4AGZE Sat, 02 April 2005 05:20 Go to previous message
i dont run one on my 4agte with gze management (i do have an emanage though).
I also disconnected it on a 4agze conversion i recently did, as after testing i couldnt find a function other than afterstart enrichment for a cold engine.
Previous Topic:Hiace V8 or V6 conversion
Next Topic:What is the Lowest F Series Diff ratio?
Current Time: Fri Nov 20 13:58:25 UTC 2026
Total time taken to generate the page: 0.0066559314727783 seconds
