Toymods » Tech & Conversions » 4age clutch
cams_ae86
4age clutch Thu, 31 March 2005 14:03 Go to next message
hey all just bought a flywheel and clutch off a small port 4age and was wondering if it would fit on my 4agze with a t-50 gear box if so can any one tell me where i can get a brass button clutch or even a 5 Puck for the 4age thanks any help would be good.
bayka
perth
Re: 4age clutch Thu, 31 March 2005 17:12 Go to previous messageGo to next message
Hey man,
1. You may have a problem using the smallport flywheel on a ZE because of differences in diamter meaning the startermotor wont contact (not 100%) However providing thats ok you should be fine. If you can bolt the smallport clutch onto your ZE flywheel then that also sounds ok...
2. the only other thing to worry about is the t50 gearbox input shaft going into the clutch assembly but im pretty sure that will go in fine because my friend is running a small port block and t-50 gearbox in his ae86...
Just wait for a few other replies cause i may be wrong
Smile
3. clutch id recommend DAIKIN / EXEDY heavy duty organic or puck clutches, heaps of ppl here use them including me and theyre fantastic. Your local autopro should be able to sort you out, mine was around $360 (clutch face, heavy duty pressure plate, and thrust bearing)
ae95
Re: 4age clutch Thu, 31 March 2005 17:23 Go to previous messageGo to next message
gze fly doesnt fit into the t50 bell
so u either got a 212mm fly hanging off ur motor or a 200mm
either way u can fit the fly wheel and clutch
dunno if the clutch will work tho
cams_ae86
Re: 4age clutch Fri, 01 April 2005 01:27 Go to previous messageGo to next message
oh thanks so the fly and clutch will fit but the clutch may not work.i was led to believe the ge and ze used the same clutch. Crying or Very Sad
ProjectSeven
February 2005
Re: 4age clutch Fri, 01 April 2005 06:56 Go to previous messageGo to next message
Nope the ZE has a larger diam flywheel and clutch. The biggest one that will fit in a t50 is off a 20v 4age. Easiest fitment is to use a 16v 4age flywheel and upgraded clutch as the starter will bolt straight up to the t50.
Hope this helps a bit.
ProjectSeven
February 2005
Re: 4age clutch Fri, 01 April 2005 06:58 Go to previous messageGo to next message
also another note is that the input shaft size is larger on a ZE clutch. It is actually the same size as in supra gearboxes. NA 4age clutches have the same input shaft size that is in a t50.
cams_ae86
Re: 4age clutch Sat, 02 April 2005 00:46 Go to previous message
ok thanks projectseven that made things a little more clear.
Previous Topic:4AGZE/4AGE iridum/platinum plugs?
Next Topic:2T Turbo?
Current Time: Fri Nov 20 15:44:40 UTC 2026
Total time taken to generate the page: 0.0046257972717285 seconds
