Toymods » Tech & Conversions » 2T Turbo?
Ta22lover
February 2005
2T Turbo? Fri, 01 April 2005 01:51 Go to next message
Hi
Im thinking about trying a 2T turbo, as far as i understan i can use a 3t turbo manifoild, but what kinda carb do i need to use? is it possible to use the standard 2t carb?
any other thing i need to do to make this mod possible?
thanks in advance Very Happy
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: 2T Turbo? Fri, 01 April 2005 02:08 Go to previous messageGo to next message
just swap in a 3tgte, believe me when I say that will be the simplest option.
Re: 2T Turbo? Fri, 01 April 2005 02:10 Go to previous messageGo to next message
I strongly recommend NOT using a carb with a turbo.
Yes you could use the stock carb if you mounted it pre-turbo (ie draw-through) but it won't flow adequate CFM once the turbo spools up. It would probably be big enough for a blow-through setup but significant mods would be required to make it work with positive pressure.
It will be much easier and far more effective to get a 2T-GEU and turbocharge that, trust me.
styler
Re: 2T Turbo? Sat, 02 April 2005 00:25 Go to previous message
3tgte will be the easiest by far, why try and do it yourself
when toyota has already designed and mass produced them Very Happy
iv also thought about it and you would need a 2tgeu block and its the same as the 3tgeu so its just a lot of hassle and a few mods to swap it all over, if you are after a good setup you will
run efi, all the parts you will need are going to be 90% a 3tgte
anyway...
Previous Topic:4age clutch
Next Topic:Whats this sticker mean???
Current Time: Fri Nov 20 15:55:20 UTC 2026
Total time taken to generate the page: 0.013929128646851 seconds
