Toymods » Tech & Conversions » Weird shuddering to near stall
Leighp
NY
icon13.gif  Weird shuddering to near stall Fri, 01 April 2005 04:16 Go to next message
I have an AE92 20v ST and it has been fine for ages, but over the last week the car as i drive seems to (at no apparent time) jsut start to chug or even nearly stall and if at the lights or stopped the idle will rise to 1500 then drop to either 1000 or 450 then go up or stall (again randomly) The wires have been untouched, so this is a real challenge for me
Does anyone know what i can do here, how to test for any wiring problems at all, I am starting to go bald trying to figure this one out, everything seems all fine and no issues, asides the above that i mention
Leigh Smile
setsuna
Re: Weird shuddering to near stall Fri, 01 April 2005 04:21 Go to previous messageGo to next message
Airflow meter? Smile
.. if it has one Razz
teeheehee
weird stuff happens if thats gone bung..
Leighp
NY
Re: Weird shuddering to near stall Fri, 01 April 2005 04:31 Go to previous messageGo to next message
it has one, what would make it go bang, and how do i test it??
Leighp
NY
Re: Weird shuddering to near stall Fri, 01 April 2005 04:48 Go to previous messageGo to next message
is my car playing an april fools joke on me??
Kyosho
Wollongong
Re: Weird shuddering to near stall Fri, 01 April 2005 06:55 Go to previous messageGo to next message
Check air filter, fuel filter...
I'm guessing it's EFI, so also check the AFM is connected properly, they can clog up with shit and die fairly randomly...
Jorrs
Coffs Harbour
Re: Weird shuddering to near stall Fri, 01 April 2005 07:18 Go to previous messageGo to next message
check your throttle body, and buy carby cleaner and clean it out really well,
bantech
Bathurst
Re: Weird shuddering to near stall Fri, 01 April 2005 11:04 Go to previous messageGo to next message
Well - this is interesting.
My AE82 86kw Corolla does the same thing - more when the car's warm, the temperatures reasonably warm (not hot) and usually with the AC on.
Without AC it shudders and stalls when slowing down to lights after the car's been running for a while. It only does it when changing down to stop. If I just slow down in neutral its fine.
My diagnostic fault codes say there's a problem with my o2 sensor.
Other than that I have an unshielded pod filter which may be drawing hot air.
FWIW - I'm going to either shield the pod filter or go back to an airbox. If that doesn't work I'll look at the o2 sensor.
Maybe you should also check your diagnostics and see if it offers any clues?
Leighp
NY
Re: Weird shuddering to near stall Fri, 01 April 2005 12:37 Go to previous message
FWIW???
FOUND THE ISSUE
the positive terminal connection was coming lose, tightened and volla, perfect car.
thanks for all teh help, now i am Very Happy again
Previous Topic:afm and map help
Next Topic:1977 ke30 needs more power!!!!
Current Time: Fri Nov 20 17:26:30 UTC 2026
Total time taken to generate the page: 0.0063309669494629 seconds
