Toymods » Tech & Conversions » Raising Compression???
Malicia
icon5.gif  Raising Compression??? Mon, 11 November 2002 09:22 Go to next message
What sort of things can be done to raise the compression of an NA engine??
Re: Raising Compression??? Mon, 11 November 2002 09:27 Go to previous messageGo to next message
Fit high top pistons, mill head, use flat valves rather than slightly dished ones, use thinner head gasket. This costs a bit of money.
rollaboy
Coffs
Re: Raising Compression??? Mon, 11 November 2002 09:41 Go to previous messageGo to next message
How do you work out / find out the new compression after doing something like that???
Re: Raising Compression??? Mon, 11 November 2002 10:22 Go to previous messageGo to next message
You cc the combustion chamber.
blackRA28
adelaide
Re: Raising Compression??? Mon, 11 November 2002 12:53 Go to previous message
word word... what sort of things are most done to 18RGeu's as a first stage of raising the comp. a little bit, as the older motors had higher, but lesser flowing heads am i right? if this is true what can i do when i freshen up my engine to get the compression up just a little to give it a little more poke and utilize the lesser-restrictive ports? Im talking about +0.5 to +1.0:1 .. is this going to boost the output of the motor noticeably much more considering will be using stock ecu and injectors? and will this affect the reliability and strength much considering i dont think i have enough to perform major TRD overhaul surgery to the old girl.
Would this need altering/reprogramming of the ECU to suit the different compression? probably hey.. or maybe it even wont be possible and worthwhile, using all other stock gear without buying a motec haha.
Cheers heaps for any comments Wink
Guy
_________________
BlackRA28
Previous Topic:3sgte to st150
Next Topic:Soarer, V8 or Turbs?
Current Time: Fri Nov 20 13:06:29 UTC 2026
Total time taken to generate the page: 0.0053811073303223 seconds
