Toymods » Tech & Conversions » st162 suspension
MCM Madness
st162 suspension Fri, 01 April 2005 05:50 Go to next message
i've got a 85 st162. the suspension is all original and the shocks are fully shot.
if i was to replace the system and lower the car.
1 - what shock spring combination would i need
2 - would i need a camber kit. front/ rear
3 - any chance i could get it done myself, if not prices on getting it done
StuC
Re: st162 suspension Fri, 01 April 2005 07:19 Go to previous messageGo to next message
KYB shocks - Try the AGX coz they're adjustable
KIng Springs
Front and Rear Sway Bars(Rear first)
Camber kit at front
Nolothane bushes
Check out whiteline=-KYB are thes best bang for buck .The AGX are more expensive but i hear good things
http://www.whiteline.com.au
MCM Madness
Re: st162 suspension Fri, 01 April 2005 13:29 Go to previous messageGo to next message
ill probably go with whiteline shocks and super low king springs.
does anyone know if the super lows are legal in victoria, they're meant to bring it down around 60mm but im not sure wether or not that will effect roadworthiness.
thanks for the reply
smashed_wombat
Re: st162 suspension Sat, 02 April 2005 16:15 Go to previous messageGo to next message
Camber / castor tops are worth the money, esp. if you decided to go super low. I dont think its legal in Victoria as just 30mm lower brings your front exhaust pipe pretty much dead on the height limit.
Jorrs
Coffs Harbour
Re: st162 suspension Sun, 03 April 2005 07:49 Go to previous messageGo to next message
just go monroe heavy duty all round, and low king springs all round Smile
Aust162
Melb, Victoria
Re: st162 suspension Sun, 03 April 2005 07:59 Go to previous messageGo to next message
superlows will make you bottom out everywhere.eg.front spoiler,exhaust system etc. and if you have bigger than factory rims,you will have to roll your guards.
you might be able to use superlows in the rear without TOO much trouble, but i cant speak from experience.
i'd look for springs that will give you about a 25-40mm drop only.
hey andy,have u got the castor/camber top adj on the front?
berad
Re: st162 suspension Sun, 03 April 2005 10:57 Go to previous messageGo to next message
ive got super lows and pedders struts i never bottom out even with 4 ppl in the car
Jorrs
Coffs Harbour
Re: st162 suspension Sun, 03 April 2005 11:25 Go to previous messageGo to next message
yeh and i meant Lows not Superlows, lows provide the car with the lowering but not to low Smile are perfect
smashed_wombat
Re: st162 suspension Sun, 03 April 2005 12:26 Go to previous message
Nah, i wish i did tho. If my car was actually 30mm lower it would have been beyond the range of the standard camber adjustment. Also would've liked the ability to fine tune the settings, play with +'ve and -'ve camber etc. I'll do it eventually... right after I work out why my car is still at standard height on king 'low's!
Also definetly adding a rear sway bar after i sort the engine out.
Previous Topic:white redline??? speedo question???
Next Topic:No power steering assistance on MX73 1JZ
Current Time: Sat Nov 21 15:03:21 UTC 2026
Total time taken to generate the page: 0.0074639320373535 seconds
