Classifieds » Miscellaneous » F/S: 4agze 176mm oversized crank pulley - Ebay
Rolla Pat
Montreal, Canada
F/S: 4agze 176mm oversized crank pulley - Ebay Mon, 11 November 2002 16:17
One 176mm oversized 4a-gze crank pulley. This pulley was professionally and carefully machined on CNC. The added pressed ring is made of stainless steel. It was also professionally balanced as you can see from the balance hole on the back of the pulley. It was made from an original OEM pulley so it retains the stock harmonic dampener which was intended by the engineers at Toyota. This pulley will make the 4a-gze supercharger turn faster and will raise boost from the stock 8 psi to a whopping 14 psi. This pulley is of the same or higher quality than other similar brand name pulleys like Cusco or Nevo. It is brand new and was never used. Owner sold engine it was meant to go onto. Do not hesitate to contact me if you have any questions.
You can bid on the item on Ebay...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?Vi ewItem&item=1872271612
Thanks!
Previous Topic:UREGENT reluctant sale
Next Topic:FS: Computer Parts
Current Time: Fri Oct 30 17:48:33 UTC 2026
Total time taken to generate the page: 0.11375403404236 seconds
