Toymods » Tech & Conversions » cams for small port 4AGE
chrishanley
icon5.gif  cams for small port 4AGE Tue, 12 November 2002 00:01 Go to next message
when i bought my car the dude gave me some cams for it and said some shit like "uh they're the right size so you dont have to use a new computer i think they are bargwanna group a racing cams" but that's it and it sounds like he was spinning shit, i know that this should mean that they are under 273' but in regards to the precise lift and duration i am in the dark. how do i measure them, i have a micrometer and a dial gauge but that is about it, if they are legit i would also like to fit them so what is involved there, also i read somewhere about a 127hp small port version of the 4age and was curious about identifying these particular engines. And finally what sort of power would a red top small port 4AGE make with these cams in a FWD rolla,
thanks fellas
IRA11Y
Club Member
Re: cams for small port 4AGE Tue, 12 November 2002 01:11 Go to previous messageGo to next message
Ok lets clear up what I do know and what I doubt is correct...
this sounds like complete trollop ..... as far as I am aware Bargwanna has never driven a 4AGE powered vehicle in a group A class, he came out of carts and formula ford/holden and 3000 series to V8.. none of which run a toyota engine.
if the cam is up to 272 degrees and about 7.6mm lift it should be able to stay within the parameters of the factory ecu of a map sensored computer, I think a AFM will handle it even better.
ok first measure the base circle to get standard hight, then measure the lift..from the bottom of the base circle to the highest point of the cam lobe then subtract the base circle from the lift measurement and that gives you total lift , as for the degree thats a bit harder and maybe you should take it to camtech or someone to figure it out for you if you dont have the tools to do it yourself. its likely to be a bit more accurate this way.
thats hard to say because every engine runs differently and has different setups...best bet is to find out if theyre legit and throw them on if theyre ok and bring the car to the next dyno day
._T_.
Re: cams for small port 4AGE Tue, 12 November 2002 02:06 Go to previous messageGo to next message
just take the cams to a cam grinder and get them clocked up - then you'll know for sure what the are.
trd billets etc are stamped, so i assume these are weldups?
T
ae86trueno
Re: cams for small port 4AGE Tue, 12 November 2002 05:37 Go to previous messageGo to next message
Hi Michael
Jason Bargwanna auctually drove a FWD corolla in 91-92 at bathurst running in Class C - Group A (1600cc), with his brother and won the class in 92. If it hadnt rained that year my good friend Peter Verheyen (1987 australian Formula Ford Champion, Ex ZakSpeed F1 Mechanic) would have won it in a Sprinter. Yes they were still running Sprinters in 92!!!!!
Ben
AE86 Trueno 4AGE
[Updated on: Tue, 12 November 2002 05:37]
IRA11Y
Club Member
Re: cams for small port 4AGE Tue, 12 November 2002 11:03 Go to previous messageGo to next message
I stand corrected Smile..that didnt show up in his Bio I read but it may have been out of date? Embarassed
chrishanley
Re: cams for small port 4AGE Thu, 14 November 2002 01:16 Go to previous messageGo to next message
Ok now, the cams are in front of me as i type...
On the exhaust cam there's the numbers "3107" in raised (about 0.25mm) writing on a 0.25mm raised rectangle, and i think the lift is about 7.45 (measured dodgily with my dad's dial guage), and the intake cam has "K.F. 6750" stamped into it, as well as a rectangle in the same place as the exh. cam, with 3897 raised on top of it. The lift on this one is about 7.35... but i'm probably pretty out with those measurements.
I snapped my timing belt yesterday but no valve mashing sounds were heard. I didn't think this was possible, dont the pistons hit the valves if the timing belt snaps? Anyway, provided everything is ok, i'll put the cams in when i put on the new belt, as long as this is possible. I am not far from a dyno so i'll hopefully limp it to there to get tuned... If it goes.
Any comments, advice etc from here?
IRA11Y
Club Member
Re: cams for small port 4AGE Thu, 14 November 2002 07:48 Go to previous messageGo to next message
Standard cam sizes are usually about 7.5mm (7.49) so there is definately no difference in your lift figures...not to say that the duration may be different though. K.F "could"? be a kelford cams mark but im not sure exactly how the stamp them.
4AGE's run a non interferance head so it is possible to break the belt and not damage the valves. It would still pay to pull it apart and have a good look though.
chrishanley
Re: cams for small port 4AGE Fri, 15 November 2002 04:03 Go to previous messageGo to next message
Ok, i measured the lift properly and it's 7.6mm on both cams, still no idea about the duration though. Any ideas as to how i'd find out if they are kelford's? the phonebook might help. Forgive me if i'm an idiot, but what exactly is an interface head? My understanding was that if the valves were allowed to open for too long (I.e. the belt snaps/timing way out) the pistons would smash up into them and bend everything out of whack, do interface heads have large enough combustion chambers so that the valves can be open when the piston is all the way up? Any ideas?
Thanks Loads
IRA11Y
Club Member
Re: cams for small port 4AGE Fri, 15 November 2002 23:07 Go to previous message
As mentioned previously the best and most accurate way to check the duration is to take it to a cam specialist and get them to dial it up. 7.6mm usually ten to be up to 272 degrees but thats no gaurauntee. You could try calling kelford and ask them if they know what it is?.
A non-interferance head is where the tolerances between the head and the piston hight is set so that if the cam belt breaks the pistons can move up and down without striking the valves when they are open..this is no gaurauntee as parts wear and stretch with heat and age so its always best to pull it apart and check it properly.
Previous Topic:Intended Sound system
Next Topic:Help car won't start
Current Time: Sun Nov 1 05:45:00 UTC 2026
Total time taken to generate the page: 0.012180805206299 seconds
