Toymods » Tech & Conversions » removing pistons from a slightly rusted block
barned01
removing pistons from a slightly rusted block Sun, 03 April 2005 23:36 Go to next message
there is a bit of surface rust on the bores of an 18r block and i want to get the pistons out to assess the bore condiion
(beyond the obvious bits of rust of coourse) and replace the rings.
if i hammer from the bottom i am worried one of the pieces of rust may not flake off and will jam the piston and break a ring land. is there a way to get them out while beilng 100 percent certain nothing could go wrong.
i was going to go at it with 1200grit wet/dry but that still won't get close to the edge of the piston and the block bore where they meet. any methods?
oh and i tried removing the crank but i can't break the seal holding the rods in otherwise i was wondering if you could take the pistons out via the bottom.
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: removing pistons from a slightly rusted block Mon, 04 April 2005 00:14 Go to previous messageGo to next message
soak the bores in wd40 for a couple of hours, then gently tap them up and down when you get it apart dont forget to hone the bores. hope this helps...
STR8 2.8
Re: removing pistons from a slightly rusted block Mon, 04 April 2005 00:16 Go to previous messageGo to next message
use something better like yield from your local machine shop.
wd40 couldnt penetrate a paper bag
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: removing pistons from a slightly rusted block Mon, 04 April 2005 00:23 Go to previous messageGo to next message
i only said wd40 cause its a known brand and of the penatrine fluids will work (i call them wizards piss) Very Happy
barned01
Re: removing pistons from a slightly rusted block Mon, 04 April 2005 01:19 Go to previous messageGo to next message
i set wd40 in the block last night.
tried this morning and it did move slightly.
enough to remove the caps and then the crank and then the pistons were able to be hit from both sides. a few taps each way more wd40 and they slowly came out.
i did use a whole can though and you are right. it doesn't seeem to penetrate much.
now i have another issue.
the no.1 piston looks like it had spun a bearing., the rod has been eaten out on the side not much left of the bearings and the crank journal has a very rough feel to it compared to the other journals.
sigh
so much for cheap rebuild.
hey are 18rc rods the same as 18rg?
i will search but if you are quicker...
people100
Rocklea qld
Re: removing pistons from a slightly rusted block Mon, 04 April 2005 02:24 Go to previous message
rc and rg rods are the same except rg are forged where rc are just cast
Previous Topic:sst to remove oil shaft bearings in 18r block
Next Topic:1UZ clickclack on startup
Current Time: Thu Oct 29 15:57:33 UTC 2026
Total time taken to generate the page: 0.0057978630065918 seconds
