Toymods » Tech & Conversions » another query on 4AGTE water lines
ae86slaver
another query on 4AGTE water lines Mon, 04 April 2005 01:53 Go to next message
Hi guys
I've been searching oh how other's have done their 4agte water lines to and from turbo, but I'm trying to get my head around if this way would be detrimental to the turbo:
Currently there are 2 water inlet/outlets from the radiator > water pump that supply water for the inlet manifold/throttle body ; I looked at my mate's setup and these supply water for exactly that.
I bought 2 T pieces this morning, (5/16 hose 8mm) and I'm planning to T off these two hoses.
Would this work? Would it be sufficient for the turbo to receive water?
I know there are alternative ways of doing it, but I already have everything needed to do it this way, and don't wanna waste more money on fittings/hoses Sad
Finally if this would work, what position would the T pieces be plugged in? cuz gravity would be coming into play and the least I'd want is less feed to the turbo.
[Updated on: Mon, 04 April 2005 01:55]
Re: another query on 4AGTE water lines Mon, 04 April 2005 02:18 Go to previous messageGo to next message
i just T-ed of the heater core lines in the AE71 - but this was mainly cos the RB25 turbo had big water fittings on it, the same size as heater hose.
I took the feed from the line that goes from the thermostat housing to the heater core, and the drain from the turbo to the line that goes from back of the head to the heater tap.
It made a bit of a mess of heater hose, but it worked pretty well.
There are about eleventy billion ways to do it Smile
Re: another query on 4AGTE water lines Mon, 04 April 2005 02:21 Go to previous messageGo to next message
eh. Grant ran his turbo without the water cooling, so any water flow is better than that Smile
ae86slaver
Re: another query on 4AGTE water lines Mon, 04 April 2005 08:04 Go to previous messageGo to next message
LOL!
no wonder that thing resides permanantly in that spot!
Re: another query on 4AGTE water lines Mon, 04 April 2005 09:44 Go to previous messageGo to next message
I did it by tapping a fitting into the water fitting on the back of the head, and brazing some bundy tube into the heater pipe that runs down the side of the block. Then I got some bundy tube, brazed banjo's on the ends that go to the turbo, and put some lengths of aeroquip hose in the middle for some 'give'. Much tidier that way!
EVOSTi
cambo
      no
Re: another query on 4AGTE water lines Mon, 04 April 2005 10:54 Go to previous messageGo to next message
i run no water cooling, even neater again. however the air filter has a tendency to melt off the front of the turbo.
feral4mr2
Bundaberg, Qld.
Re: another query on 4AGTE water lines Mon, 04 April 2005 11:11 Go to previous messageGo to next message
tee into your heater lines, too easy. HK$ did it that way with their Mr2 turbo kit, so it must work. works fine for me too. Smile
EVOSTi
cambo
      no
Re: another query on 4AGTE water lines Mon, 04 April 2005 11:17 Go to previous messageGo to next message
while we're not on the subject, does anyone know where to get the silver reflective heat shield tube stuff that goes over water lines and the like? and roughly what its worth?
ae86slaver
Re: another query on 4AGTE water lines Mon, 04 April 2005 12:18 Go to previous messageGo to next message
hmm air conditioning places ?
well i T'ed off as mentioned - off the inlet mani/TB lines, but the water supply is more direct for the turbo cuz i've angled the T so that it flows more for the turbo
hope it works Smile
monkeymajik
Re: another query on 4AGTE water lines Tue, 05 April 2005 13:46 Go to previous messageGo to next message
That's how mine is setup. No dramas here, yet Very Happy
Re: another query on 4AGTE water lines Tue, 05 April 2005 14:06 Go to previous message
With what I did it's still going to the same places as both heater hoses, it's just tidier than having bits of heater hose everywhere. If you're on a tight budget though, go grab a couple of 202 commodore heater hoses - a right angle with a fair length of straight hose, and not too bad at around $5 each. Very handy for doing jobs like this, or LPG conversions.
Previous Topic:Corona 2sc
Next Topic:1jz-gte fault codes
Current Time: Mon Oct 19 17:51:11 UTC 2026
Total time taken to generate the page: 0.0052340030670166 seconds
