Toymods » Tech & Conversions » Weber DGV Fast Idle Adjustment
Razor
Weber DGV Fast Idle Adjustment Mon, 04 April 2005 02:32 Go to next message
I got an electric weber dgv
I want to know exactly how you set the fast idle when cold
do you screw in the fast idle screw till it touches the cam when the choke butterfly is open or close? and set it to higher rpm than idle depending on the weather.
I tried it when the choke is closed so the screw touches the cam but the butterfly wont open cos of the screw and cam getting stuck. Also when engine is getting cold the butterfly wont close as the screw is on the way of the fast idle cam.
redline states that you have to adjust it when the butterfly is open but then it wont touch the fast idle cam....
Any advice would be great
Cheers!
Razor
Re: Weber DGV Fast Idle Adjustment Tue, 05 April 2005 21:11 Go to previous messageGo to next message
bump
Razor
Re: Weber DGV Fast Idle Adjustment Mon, 11 April 2005 07:16 Go to previous messageGo to next message
anyone? I need help to set this up properly
amichie
Home
Re: Weber DGV Fast Idle Adjustment Mon, 11 April 2005 07:32 Go to previous messageGo to next message
Have you tried the Haynes weber manual?
Razor
Re: Weber DGV Fast Idle Adjustment Mon, 11 April 2005 21:09 Go to previous message
no I cant find haynes
but I have a weber manual but only tells you the jets, float setting and the parts not adjustment of the choke or fast idle
Previous Topic:Need Auto Electrical Help in Adelaide PLEASE :-)
Next Topic:stroke 4AGTE
Current Time: Fri Nov 20 09:23:51 UTC 2026
Total time taken to generate the page: 0.0057291984558105 seconds
